Husky 853 and a H16
15 replies to this topic
#1 Yats89 OFFLINE
Yats89
  • 6 Thanks
  • 7 posts
Posted May 21, 2017 - 03:48 PM
I picked up a pair of bolens and attachments the other day and I don't know anything about them. Any help would be appreciated. One is the husky 853 and the other is an H16. The attachment's​ are 2 mower decks, 2 blades, and a tiller.
  • chieffan and 637Yeoman have said thanks
#2 Bolens 1000 OFFLINE
  • 17554 Thanks
  • 18863 posts
Posted May 21, 2017 - 04:14 PM
Welcome to GTT!
We would love to see some pictures of your machines!
What would you like to know about your tractors?
I wrote an atricle on the tubeframe line if you would like to look at that
http://gardentractor...s-1962-1978-r68
  • boyscout862, chieffan, 637Yeoman and 2 others have said thanks
#3 Merle013 OFFLINE
Merle013
    If I can't do it slow then it's not going to get done.
  • 388 Thanks
  • 252 posts
Posted May 21, 2017 - 05:31 PM
Welcome to the site. You should check out the manuals section. Should be a manual or two in there that could help you out. Just got my first Bolens the other day. They sure are nice built machines.
  • boyscout862, chieffan and Yats89 have said thanks
#4 boyscout862 OFFLINE
  • 15265 Thanks
  • 10024 posts
Posted May 21, 2017 - 05:52 PM
Welcome to GTT. Two good machines. Do they run? There are owners, parts, and shop manuals for them in our Manuals Section(3 free downloads per day). Post pics when you can. Ask questions. We are all in this together. Good Luck, Rick
  • Yats89 said thank you
#5 blackjackjakexxix ONLINE
blackjackjakexxix
    Blackjackjakexxix
  • 3726 Thanks
  • 2367 posts
Posted May 21, 2017 - 06:26 PM
Welcome aboard,lots of good info here
#6 Yats89 OFFLINE
Yats89
  • 6 Thanks
  • 7 posts
Posted May 22, 2017 - 08:29 AM
Thanks for the warm welcome. I have been able to start the husky it just has a small leak by the carb. The H16 however needs rewired. But the motor turns free so I'm hopeful I can get it to run. My main question is about the rewiring. But I'm also wondering if the implements are compatible with my machine. I'll get pics up when I get off work.
  • Bolens 1000 said thank you
#7 Bolens 1000 OFFLINE
  • 17554 Thanks
  • 18863 posts
Posted May 22, 2017 - 10:05 AM
In the manuals section of our site is the Tubeframe service manual with wiring diagrams
#8 Yats89 OFFLINE
Yats89
  • 6 Thanks
  • 7 posts
Posted May 22, 2017 - 04:24 PM
Here they are
  • Bolens 1000, boyscout862 and Merle013 have said thanks
#9 Yats89 OFFLINE
Yats89
  • 6 Thanks
  • 7 posts
Posted May 22, 2017 - 06:14 PM
This is off one of the mower decks
#10 Bolens 1000 OFFLINE
  • 17554 Thanks
  • 18863 posts
Posted May 23, 2017 - 07:56 PM
Looks like they are mostly there minus a few cosmetic things
The front tires on the 853 are not the right rim size, It looks like they took them off the 853 and put them on the H16
Almost all tubeframe attachments are interchangeable minus a handful of things
  • wilberj and Yats89 have said thanks
#11 Yats89 OFFLINE
Yats89
  • 6 Thanks
  • 7 posts
Posted May 30, 2017 - 05:09 AM
I've spent some time working on these now and have to ask where should the PTO be located? I can't find anything that looks remotely close.
#12 Yats89 OFFLINE
Yats89
  • 6 Thanks
  • 7 posts
Posted June 02, 2017 - 04:36 PM
Got the husky motor running PTO was taken off but got it put back on and turning nicely. But for some reason it doesn't want to take off any suggestions on it?
#13 Bolens 1000 OFFLINE
  • 17554 Thanks
  • 18863 posts
Posted June 02, 2017 - 07:18 PM
PTO is controlled by a tensioner system that engages your PTO belts
#14 Yats89 OFFLINE
Yats89
  • 6 Thanks
  • 7 posts
Posted June 02, 2017 - 09:03 PM
The husky is running properly and I tilled a section of my garden up... Now the H16 I have found has no PTO at all it's been removed. And the ignition switch is locked up. Any chance of replacement parts?
#15 Bolens 1000 OFFLINE
  • 17554 Thanks
  • 18863 posts
Posted June 03, 2017 - 06:23 AM
The cast iron PTO's are interchangeable on the tubeframes just make sure you get one for dual belts.
Ignition switches I stock new for the H16
http://bolenspartsan...-free-shipping/
