Seat pan needed for tube frame
2 replies to this topic
#1 glgrumpy OFFLINE
  • 9122 Thanks
  • 8205 posts
Posted May 21, 2017 - 03:32 AM
Have G9 and G14's with rough pans. PO cut it out at back and center. One just rusted out at seat mount and other areas. This seems common. So, what models will have same? I'm using seat with big spring and front swivel blocks. I see some that bolt to footboards, mine dont. What's this usually sell for? Any of you Bolens Guy's have one?
  • chieffan said thank you
#2 chieffan OFFLINE
  • 16606 Thanks
  • 9090 posts
Posted May 21, 2017 - 07:23 AM
Sounds like your using a seat from an XL series.  I MIGHT have a good pan, will have to check.  Shipping that far might be a killer though.
Only thing I have is for a Cub Cadet.  Complete new rubber type seat is $50 at Orschelns.  Probably the same at TS, etc.
Edited by chieffan, May 21, 2017 - 10:22 AM.
#3 glgrumpy OFFLINE
  • 9122 Thanks
  • 8205 posts
Posted May 21, 2017 - 02:38 PM
Gonna take a picture of what I have now. Don't need seat or mount, just the tins. I had one sort of fixed at weld shop that I'm gonna use.
Went out and moved stuff around and took pix of the pan. The G14 will be fine, that one I had fixed and looks ok. G9 one is the cut-up one and could be newer or better one for that. I was also looking at my QT16 pan, which also seemed bad, but now looking, see that the cut-out in back was for the 3pt and I can straighten that area and get most rust off and be fine.
Edited by glgrumpy, May 21, 2017 - 07:17 PM.
