I have a 1972 or so landlord 3410.. I toasted the clutch any one know where I may find a new one? the nut came loose and wallered out the drum and the pulley
I broke the center pto clutch
#1
OFFLINE
Posted May 20, 2017 - 07:10 AM
#2
OFFLINE
Posted May 20, 2017 - 10:14 AM
Here is a couple links for parts. Your local Simplicity can also get them.
https://www.jackssma.../power-take-off
http://www.partstree...power-take-off/
#3
OFFLINE
Posted May 20, 2017 - 07:20 PM
thanks I need part number 7 clutch plate and number 6 pulley not available I do believe. I found jacks last night thanks for the links!
#4
OFFLINE
Posted May 27, 2017 - 08:33 AM
I fixed it! for how long I don't know? I welded a bead well several on the worn grove on the clutch drum ground it down a lot then spot welded the pulley ground it down a bit. Well with its new blades and belts it throws the grass 4 to 5 ft !
