2754 GLS info needed
15 replies to this topic
#16 glgrumpy OFFLINE
  • 8,816 Thanks
  • 8,014 posts
Posted September 13, 2017 - 05:53 PM
Update: Took float bowl off, no fuel. Pulled apart at the filter and blew air into line into tank. Man, should have seen that puff up right away@ Then fuel coming back out real fast under pressure. After I let finger off, was running real strong. Put it back on filter, and it started right up. SO, guess some gunk in line or tank fitting?? I let run quite awhile, then took little spin on it, and drove back to put in garage space for winter close-up. Will be spring before any more work is done on it.
