Paid $50 for tractor w/out engine, sound familiar? Whole rig not old. Can I get date from ID numbers? Not sure where to go for this on'line. Think they are made by AYP or they bought them or something?? When first seen it had a blade on it, no deck, and chains. Would not roll, even with the wire out back pulled out. We got it back to our site and took off the blade and chains, then turned it up on side some. Seemed the brake was sticking. We remove the caliper and now tractor pushes with wire pull out, locks when it is put back in. SO, hoping the rear is ok. Has vertical engine originally. KInda expensive and harder to find used, so thinking of just trying to put in Briggs or other vertical twin of smaller size to get it to be run-able. Belt drive back to trans. Not sure if should have electric pto or just what, there is a space in the dash with nothing in it, labeled mower start. Looks too big to be just a switch and no wires near there. ARe they mechanical? Will have to find some manuals, not sure yet if anything on here. Guess could try brand on web and see where it goes.
Model 960430066 00
Serial 042409B001657
Is there a place to tell how to read these?
Model 960430066 00
