PTO Clutch pictures - What do I look for to determine wear?
11 replies to this topic
#1 JDBrian OFFLINE
  • 9,624 Thanks
  • 14,150 posts
Posted June 15, 2011 - 07:06 PM
Hi Folks
I have been ignoring the PTO clutch but decided to have a look at it. It came apart without much fuss. The coil looks like it's been recently replaced and reads a low resistance. Something like 3 ohms if I recall correctly. The bearing is toasted and I have a new one. I got the bearing out of the pulley but I'll need to press the bushing out of it. In the first picture of the back side of the pulley - Is this the wear area of the clutch? The rivets are still below the shiny surface but not by a lot. I've never had one of these apart before. I don't even have a use for it now but want to know it's condition and repair if required before I put the engine back together. At least the coil is in good shape.
#2 olcowhand ONLINE
  • 41,126 Thanks
  • 31,411 posts
Posted June 15, 2011 - 07:08 PM
That coil is definitely new, and the rest looks fine. I'd just install the new bearing & call that job done.
#3 JDBrian OFFLINE
  • 9,624 Thanks
  • 14,150 posts
Posted June 15, 2011 - 07:23 PM
The coil is definitely new. I think it is an expensive part and was surprised to see it had been replaced. The clutch had not been adjusted properly and had no hope of working. The gap was way too wide and the springs were not adjusted evenly. The rotating part was rubbing lightly against one side of the coil. I need a press to get the bushing out of the bearing and press it into the new one. I have one in my shop at work that will do the job.
#4 NUTNDUN OFFLINE
  • 10,339 Thanks
Posted June 19, 2011 - 03:20 PM
I need to get a press also. It is on my short list of needed tools along with about 10 pages of other stuff in fine print LOL.
Clutch looks good. Like Dan said I would just put the new bearing in and call it a job well done. The clutch material will more then likely last longer then the tractor as long as you have the gap set right so it doesn't slip when engaged. My pto clutch ended up having the fingers break, I think it was two of them that broke and Dan hooked me up with a new finger and a couple of rivets and I got it back together. I actually still have it since I stripped it off the Snapper before I sold it.
#5 JDBrian OFFLINE
  • 9,624 Thanks
  • 14,150 posts
Posted June 19, 2011 - 03:31 PM
I got the bearing changed out and it is ready to reinstall on the motor. The press makes it easy to press out the bushing and reinstall the bearing but you need to use something to rest on the rivets to protect the fingers from taking the strain when you press it in. This is the first new part I have found when taking apart pieces of the tractor that weren't working. The clutch would not engage but was not adjusted at all. It must have had a gap of 1/8 inch! It could also be the switch. I am just getting to the electrical and it has been butchered. I have yet to find the reason. I suspect the PTO switch may be bad and to compensate they rewired it to use the second set of safety contacts of the switch. Then they bypassed the seat switch and PTO safety switch wiring. I will sort that out before putting the tractor back in service.
#6 mikebramel OFFLINE
mikebramel
    Ron Paul
  • 177 Thanks
  • 1,009 posts
Posted June 19, 2011 - 03:59 PM
3 ohms is the right resistance
#7 robertbennet OFFLINE
robertbennet
  • 1 Thanks
  • 5 posts
Posted June 19, 2011 - 06:00 PM
3 ohms is right
#8 JDBrian OFFLINE
  • 9,624 Thanks
  • 14,150 posts
Posted June 20, 2011 - 08:30 AM
I figured it was good. There is a fuse wired in series with the coil so there must have been problems at some point. The coil assembly was scraping on the rotating plate of the clutch. Just enough to wear the paint off the side in one spot. I'll clean up the inside of the plate before I install it and make sure the coil assy. is centred and that should take care of that problem. Tonight I'll check the switch out and start rewiring the safety interlock.
#9 dstaggs OFFLINE
dstaggs
    In Remembrance, RIP Dale
  • RIP
  • 554 Thanks
  • 1,781 posts
Posted June 20, 2011 - 12:50 PM
Thankful that was a simple fix.
#10 EricFromPa ONLINE
EricFromPa
  • 3,657 Thanks
  • 3,112 posts
Posted June 21, 2011 - 12:46 PM
If all else fails you can rewire the pto,use a heavy 4 wire relay and a cheap toggle switch.Those toggle switch covers are pretty cool looking and they come in all different colors they will also help to keep the switch dry.
Safety Cover for Toggle Switch - Assorted Colors
If you need help wiring a relay up I can make up a diagram for ya.
#11 JDBrian OFFLINE
  • 9,624 Thanks
  • 14,150 posts
Posted June 25, 2011 - 09:04 AM
Thanks Eric. I got it all sorted out now. Rewired it as per the factory diagram. The switch now measures very low resistance in all settings and is in good shape internally. Thanks for the link.
#12 JDBrian OFFLINE
  • 9,624 Thanks
  • 14,150 posts
Posted June 25, 2011 - 02:46 PM
I just finished installing the clutch on the engine and adjusting it. With the switch repaired and the clutch with a new bearing and properly adjusted I should be good to go. I'm close to putting the engine back in the tractor!!
