Yard Man 22 hp Kohler Horizontal
20 replies to this topic
#1 MolonLabe OFFLINE
MolonLabe
    Rust Wrangler
  • 551 Thanks
  • 319 posts
Posted May 15, 2017 - 03:49 PM
I have been looking for an MTD 990 for a while when I found this Yard Man. It was listed on CL for some time and upon seeing the colors I automatically ignored it. Well, today I took a closer look and found what appears to be a White dressed in green and yellow. I know absolutely nothing about these machines but given the features decided to bring it home. Any info on these would certainly be appreciated.
Regards,
  • Cvans, Leonard VanCamp, 637Yeoman and 1 other said thanks
#2 Rock farmer ONLINE
Rock farmer
  • 1,197 Thanks
  • 1,232 posts
Posted May 15, 2017 - 04:21 PM
That looks to be a 995.
The lights on the rear fenders say "White" to me.
I think there may have been something else MTD did just for White
Do you think it may have been made for white, then, repainted and sold as a Yardman?
Joe
  • MolonLabe and 637Yeoman have said thanks
#3 Trav1s ONLINE
Trav1s
  • 3,162 Thanks
  • 4,275 posts
Posted May 15, 2017 - 04:30 PM
Looks quite beefy
#4 MolonLabe OFFLINE
MolonLabe
    Rust Wrangler
  • 551 Thanks
  • 319 posts
Posted May 15, 2017 - 04:50 PM
I had the right side cover off for those pics to see what oil filter it used. Here is what it looks like with the side cover on. The louvers sure look like a White but I can't find a 22 hp model with the Kohler CH22S engine listed anywhere.
  • Leonard VanCamp, 637Yeoman and Mark 149 J. have said thanks
#5 firefight100 OFFLINE
firefight100
  • 20 Thanks
  • 19 posts
Posted May 15, 2017 - 05:25 PM
I have a White and it is a 18hp briggs.  Also the White had a different grill that said white as well as White labeled decals on the side of the hood.  I think MTD made this for Yardman.
#6 Canawler OFFLINE
Canawler
  • 1,948 Thanks
  • 1,801 posts
Posted May 15, 2017 - 06:57 PM
It's a model 999 made from '95 to '98 per the available manuals on MTD's website. It was the last in the 990 tractor family. I don't believe they had a White version with that engine, only a 20hp (model 992, '95-'99.) Yardman was just an MTD brand after, I think, '74 or '75.
Edited by Canawler, May 15, 2017 - 07:03 PM.
  • MolonLabe, 637Yeoman and Mark 149 J. have said thanks
#7 lrhredjb ONLINE
lrhredjb
  • 655 Thanks
  • 547 posts
Posted May 15, 2017 - 07:21 PM
Looks pretty stout, maybe a few rattle cans if you don't like the paint scheme.
  • MolonLabe said thank you
#8 MolonLabe OFFLINE
MolonLabe
    Rust Wrangler
  • 551 Thanks
  • 319 posts
Posted May 15, 2017 - 07:40 PM
Thank You! I couldn't find a model with the Kohler engine but everything else looks correct.
I'm thinking of replacing the yellow with olive drab for a two-tone green..... :D
#9 glgrumpy OFFLINE
  • 8,549 Thanks
  • 7,877 posts
Posted May 15, 2017 - 07:46 PM
Almost Deere colors, better keep, worth more when selling later, ha!  Sure looks like White I had, but don't recall what engine. Think was a V-twin, but might have been Briggs?  I had carb trouble and never did get it to run right. Was nice heavy tractor on all the other areas.  Far as Yardman stuff, think MTD is still making many items with that name still. I see them for sale in push mowers and tillers and other items in stores.
#10 Tomwendt ONLINE
Tomwendt
  • 133 Thanks
  • 148 posts
Posted May 15, 2017 - 08:16 PM
i have a white 2055 with a 20 hp vanguard and it looks like the same machine except the colors.
#11 Canawler OFFLINE
Canawler
  • 1,948 Thanks
  • 1,801 posts
Posted May 15, 2017 - 10:16 PM
The 22hp Command is correct for a 999. The manuals for those and all the MTD tractors are available for free on MTD's website.
  • sacsr and MolonLabe have said thanks
#12 MolonLabe OFFLINE
MolonLabe
    Rust Wrangler
  • 551 Thanks
  • 319 posts
Posted May 16, 2017 - 07:50 AM
Sadly, the model and serial numbers no longer reside on the tractor due to the seat being replaced. That makes it impossible to find the correct manual on the MTD site.
Update: Found a picture of a model number and serial. The model is a 145-999-501
Edited by MolonLabe, May 16, 2017 - 09:30 AM.
#13 Utah Smitty OFFLINE
Utah Smitty
  • 1,701 Thanks
  • 1,781 posts
Posted May 17, 2017 - 09:19 PM
I have a Dayton 3Z678 that's very similar other than it uses the 18hp B&S flat twin horizontal.  Some of the MTD995-based tractors had problems with the steering gears.  The sector and pinion had very fine teeth and they'd tend to skip after a while.  My first Dayton had that problem and I could never get rid of it.
I just bought another Dayton 3Z678, and the steering seems to work okay so maybe the fixed the problem.
Smitty
Edited by Utah Smitty, May 17, 2017 - 09:19 PM.
#14 Canawler OFFLINE
Canawler
  • 1,948 Thanks
  • 1,801 posts
Posted May 18, 2017 - 10:11 AM
For future reference, to find a manual on their site, you don't need the full model number and you can use any number for the serial. In the model number you posted, "14" represents the product line, garden tractor in this case, and "5" is a model year, 1995 in this case. There are manuals available for 145999, 146999, 147999, and 148999. If you don't know what model year your tractor is, the numbers on the engine will tell you what year it was built. You can figure the tractor model year from that.
  • sacsr, Rock farmer and MolonLabe have said thanks
#15 MolonLabe OFFLINE
MolonLabe
    Rust Wrangler
  • 551 Thanks
  • 319 posts
Posted May 23, 2017 - 06:29 AM
Took a couple of size comparison pics yesterday while I had the Wheel Horse C-101 out for mowing duty.
Later changed the hydro oil and filter. Draining the transaxle wasn't bad but filling it was a chore. Forget using a funnel, the tube is too small and burps the fluid right back out. Had to resort to siphoning it in through a piece of 3/8 vinyl tubing. Took over an hour to put 6 quarts in.
  • KennyP, sacsr and Mark 149 J. have said thanks
