my new to me white 1650
33 replies to this topic
#16 Sawdust ONLINE
Sawdust
  • 5,678 Thanks
  • 3,381 posts
Posted June 02, 2017 - 08:51 AM
Nice Gt I love my 990. The Whites are hard to find & yours looks in good shape. Shop around for the fan, I found mine on eBay for about $20. Mine was hard to get off because the rear yoke was froze to the shaft but after a few days of soaking im PB Blaster it finally came loose. These Gt's are a beast. Welcome to the forum & keep us posted.
Edited by Sawdust, June 02, 2017 - 08:52 AM.
  • MolonLabe, archer and Jwsoup have said thanks
#17 archer OFFLINE
archer
  • 11 Thanks
  • 17 posts
Posted June 02, 2017 - 08:55 AM
Here's the new one
#18 archer OFFLINE
archer
  • 11 Thanks
  • 17 posts
Posted June 02, 2017 - 08:58 AM
Here's the picture
  • Mark 149 J. said thank you
#19 archer OFFLINE
archer
  • 11 Thanks
  • 17 posts
Posted June 02, 2017 - 09:43 AM
Do you happen to have a good part number for the outer rear axle seal? The pe788049 seams to be obsolete.
Sent from my RS500 using Tapatalk
#20 Mark 149 J. ONLINE
Mark 149 J.
    Mark J.
  • 2,404 Thanks
  • 1,352 posts
Posted June 02, 2017 - 09:59 AM
The 990 looks to be in great shape!  Do you have any more pictures of White and the 990?  I would love to seem more!
I've seen lots of the 990 with broken 3 point axle tubes.  It must be a weak spot or people think there tractors can lift anything.
  • Sawdust and archer have said thanks
#21 Sawdust ONLINE
Sawdust
  • 5,678 Thanks
  • 3,381 posts
Posted June 02, 2017 - 12:43 PM
A lot of these seals & bearings can be cross referenced from suppliers like Timken or SKF. Here is a link from Sears that has this seal.
http://www.searspart...9/0071/143.html
  • archer said thank you
#22 archer OFFLINE
archer
  • 11 Thanks
  • 17 posts
Posted June 02, 2017 - 09:20 PM
Here's a couple pictures of both.
#23 Mark 149 J. ONLINE
Mark 149 J.
    Mark J.
  • 2,404 Thanks
  • 1,352 posts
Posted June 02, 2017 - 10:13 PM
I really like the looks of the White!
#24 archer OFFLINE
archer
  • 11 Thanks
  • 17 posts
Posted June 02, 2017 - 10:21 PM
Thanks, me too.
#25 VTXrider OFFLINE
VTXrider
  • 517 Thanks
  • 376 posts
Posted June 03, 2017 - 10:28 AM
Just use the number without the "PE". I bought a couple from Ebay last year. Check the axle before installing, mine was scored and had to put a sleave over the damaged area. Tip: jack the axle up high so the oil does not run out.
Nice looking tractors. I used my tiller recently and it does a good job. The drive shaft is shaky but it held up.
Edited by VTXrider, June 05, 2017 - 09:01 AM.
#26 archer OFFLINE
archer
  • 11 Thanks
  • 17 posts
Posted June 06, 2017 - 11:06 AM
I know i can find them online but does anyone have a crossreference number to something like timken so i can pick up at my local bearing supplier? Can't seem to find the specs.
#27 Sawdust ONLINE
Sawdust
  • 5,678 Thanks
  • 3,381 posts
Posted June 06, 2017 - 01:26 PM
Timken has their own cross reference pdf file on their website. Call Napa & tell them what you need using the 788049 number & see what they can do. If you have yours out maybe take it with you.
#28 Jwsoup OFFLINE
Jwsoup
  • 2 Thanks
  • 5 posts
Posted August 09, 2017 - 10:03 PM
Very nice. Is the tiller pto or hydraulic powered?
I got my first gt last year its an 18hp yardman ( mtd995). I've heard its the same as a white 1850 if im not mistaken
#29 archer OFFLINE
archer
  • 11 Thanks
  • 17 posts
Posted October 22, 2017 - 09:22 PM
Sorry for not replying. The tiller is pto power.
Sent from my SM-G900R6 using Tapatalk
#30 archer OFFLINE
archer
  • 11 Thanks
  • 17 posts
Posted October 28, 2017 - 04:31 PM
Well finally installed new fan on the yoke for the pump. I removed the fenders and tunnel. Then I separated the axle and pump from the frame. The yoke was very stubborn. Ended up using a ball joint fork along with some heat on the yoke. Not sure I'd recommend it though. I was worried about to much pressure pulling on the shaft. It did work though. So far pump still works.
