Opps
5 replies to this topic
#1 1978murray OFFLINE
1978murray
    diesel mechanic
  • 607 Thanks
  • 1,165 posts
Posted June 15, 2011 - 06:37 PM
Well yesterday I was working on the panzer 1107. I was messing with the belt tension and took the upper drive rest casting off and when I was tightening it to put it back on the cracked the casting in half. IDK how much a replacement will be. any help
#2 olcowhand ONLINE
  • 42,428 Thanks
  • 31,811 posts
Posted June 15, 2011 - 06:40 PM
Cast iron or cast aluminum? Either way, easy enough to weld or have welded.
#3 Bolens 1000 ONLINE
  • 15,291 Thanks
  • 18,235 posts
Posted June 15, 2011 - 06:43 PM
:ditto: I would think it is weldable....
#4 tankdriver OFFLINE
tankdriver
  • 2 Thanks
  • 23 posts
Posted June 15, 2011 - 08:10 PM
It's weldable....... Find a good local welder shop.
#5 NUTNDUN OFFLINE
  • 10,350 Thanks
Posted June 15, 2011 - 08:18 PM
Like the others have mentioned I would have it welded. Will be a lot easier and more then likely a lot cheaper then trying to find a replacement.
#6 scrapiron OFFLINE
scrapiron
  • 1 Thanks
  • 104 posts
Posted September 03, 2011 - 11:24 PM
have it welded.
