Having trouble finding wheel horse belt numbers
#1
OFFLINE
Posted May 14, 2017 - 05:18 PM
#2
OFFLINE
Posted May 14, 2017 - 07:04 PM
Red Square has a BUNCH of manuals.They had a 36,37,42 and 48" deck for the 300 series.Found my drive belt and idler pulley part numbers over there.
http://www.wheelhors...wer-decks-reel/
http://www.wheelhors...-37sc01-iplpdf/
http://www.wheelhors...4-om-ipl-snpdf/
http://www.wheelhors...5-om-ipl-snpdf/
http://www.wheelhors...7sc01-om-snpdf/
Hey check out the Wheel Horse I got off of Charlie.Waiting on parts but she runs and mows.I need to get another tube for the other 23 10.50 12 tire I'm putting on it.There Craftsman GT18 wheels.The offset is Perfect for the wheel horse.Original rear tires are Junk.Had to stuck an old Bolens wheel on it temporarily.
Mine is a 1996 Wheel Horse 312-8 Model number 73428 with 36" deck.Can't read the number on the deck.
Tractor model 73428
Deck model looks like 73315
Edited by EricFromPa, May 14, 2017 - 07:06 PM.
- Tecumseh power said thank you
#3
OFFLINE
Posted May 14, 2017 - 09:23 PM
I don't understand this wheel horse stuff they make a deck manual but has no part numbers in it. Lol all I want is both belts. They must not want you to be able to buy themRed Square has a BUNCH of manuals.They had a 36,37,42 and 48" deck for the 300 series.Found my drive belt and idler pulley part numbers over there.
Mine is a 1996 Wheel Horse 312-8 Model number 73428 with 36" deck.Can't read the number on the deck.IMG_20170514_193635.jpg
#4
OFFLINE
Posted May 14, 2017 - 09:32 PM
#5
ONLINE
Posted May 15, 2017 - 07:45 AM
Do you have the Toro Parts Viewer? https://lookup3.toro...fm?xCaller=Toro
What is the model number of your tractor?
#6
OFFLINE
Posted June 02, 2017 - 10:06 PM
My deck is the 37" 2 blade side discharge. Just ordered a pair of belts for it off of ebay. 1/2" x 141". Found them SUPER CHEAP so I ordered 2 and 1 for my Cub 582 44C deck. OEM Toro belt is almost $60 and a good Gates belt is $32-$38 for that size.
http://www.ebay.com/...=STRK:MEBIDX:IT
Top left deck here is the 36" rear discharge. Top Right is the 2 blade 37" side discharge deck like mine.
Bottom Left is the 3 blade 42" Rear discharge. Bottom Right is the 3 blade 42 and 48" 3 blade side discharge deck.
Which 1 do you need a parts manual for? Measure the mower from underneath Blade tip to Blade tip to get the correct size of the deck.
Edited by EricFromPa, June 02, 2017 - 10:11 PM.
#7
OFFLINE
Posted June 04, 2017 - 05:13 AM
I have a 314a with a 38" deck. I can't find the deck number I think it was missing when I got it . Since I can't find the number I can't find the part numbers for the blade belt on the deck and from the pto to the deck. Does anyone know the sizes. Or the part number for the 38" deck so I can look up the diagram because I may need a spindle too. Can't find what I need in the manuals section.
The 314-A is a 1985 model using 21-14KE01 for a model number.
There is a 36" rear discharge deck model 05-36MR03 listed for this tractor.
http://www.wheelhors...mr03-ipl-snpdf/
This may not be the exact model you have but the belts will be the same.
More important info
http://www.wheelhors...er-spindlespdf/
Garry
#8
OFFLINE
Posted June 04, 2017 - 05:20 AM
Tractor model 73428
This is a 1998 model 73428 312-8 by the 8901203 serial number. (Reverse the first 2 digits)
The 37" 2-blade deck is model 78315
http://www.wheelhors...78315-om-snpdf/
http://www.wheelhors...8-78315-iplpdf/
Garry
