Clutch/Brake lever
8 replies to this topic
#1 maverickfe OFFLINE
maverickfe
  • 2 posts
Posted May 14, 2017 - 12:26 PM
Hello everyone new here. Ok this is what I have a Craftsman Lawn Tractor that's my wife's grandmothers that I'm fixing just got done fixing the burned up wires so now when I push in the clutch break pedal nothing really happens so if I'm on it cutting grass it will not stop just keeps going lol. So anyone know where I should look for there is nothing in the manual about it at all. The model is 917.272072
Thanks
#2 boyscout862 OFFLINE
  • 15196 Thanks
  • 10000 posts
Posted May 14, 2017 - 01:40 PM
Welcome to GTT. It sounds like some of the linkage may have come apart. There are rods to the brake and the clutch system. Follow them from the pedal and the shaft that it is on, to each function. Sometime the brakes and clutch need adjustment. That should be in the manual. If not, check our Manuals Section. Good Luck, Rick
#3 EricFromPa OFFLINE
EricFromPa
    Fixer of Broken junk
  • 6773 Thanks
  • 4562 posts
Posted May 14, 2017 - 02:12 PM
The pins like to Gaul fast inside the caliper.You will have to pull the caliper off and pull both pins and clean it up.I like to run a drill bit through the holes to clean them out.Then put Anti Seize or heavy duty greese ONLY ON THE PINS and reinstall and adjust.
#4 TomLGT195 OFFLINE
TomLGT195
  • 4155 Thanks
  • 2947 posts
Posted May 14, 2017 - 05:04 PM
:welcometogttalk:
#5 KennyP ONLINE
  • 52638 Thanks
  • 53133 posts
Posted May 14, 2017 - 06:12 PM
:wave: Welcome to the forum! I'm feeding my face right now, but I'll check Sears Parts soon to see what machine this is.
#6 KennyP ONLINE
  • 52638 Thanks
  • 53133 posts
Posted May 14, 2017 - 06:36 PM
So you have no clutch or brake? This looks to be a newer than 2000 model, probably similar to my DLT.
#7 KennyP ONLINE
  • 52638 Thanks
  • 53133 posts
Posted May 14, 2017 - 06:57 PM
Here's a parts pic from Sears.
Lower RH corner is the clutch/brake linkage.
#8 MH81 OFFLINE
  • 30055 Thanks
  • 29761 posts
Posted May 14, 2017 - 09:02 PM
If the belt is original or OEM, I would check routing to make certain it's not off or over any of the belt guides. The ones especially around the engine pulley are very important for clutching.
#9 maverickfe OFFLINE
maverickfe
  • 2 posts
Posted May 14, 2017 - 10:29 PM
thanks for all the info on it . I did look at i did try to adjust it but still nothing lloks like i have have to go into it more. The part numbers I tried to adjust was 19 nothing.
Edited by maverickfe, May 14, 2017 - 11:08 PM.
