How do you shift?
27 replies to this topic
#1 Greasy6020 ONLINE
Greasy6020
  • 1,376 Thanks
  • 1,333 posts
Posted May 13, 2017 - 10:40 PM
Gears...
Do you do any rolling shifts, say from 2nd to 3rd?
I don't care for the idea of starting out in high gear (on say my roper, 6th gear) pulling anything... I also tend to do wheelies and/burnouts then
Does anyone else do rolling shifts?
Edited by Greasy6020, May 13, 2017 - 10:56 PM.
#2 bbuckler ONLINE
bbuckler
  • 3,316 Thanks
  • 2,974 posts
Posted May 13, 2017 - 10:43 PM
I mow in 2nd high I pull in 2nd low and I travel in 3rd High.
  • Greasy6020 said thank you
#3 637Yeoman OFFLINE
637Yeoman
  • 1,551 Thanks
  • 1,254 posts
Posted May 13, 2017 - 10:53 PM
I dont have any hi/lo gears. I mow in second, plow in third *snow* Molboard plow in second, pushblade dirt in second. For pulling heavy loads, i start in third, if its a far distance. What i do is i start out low throttle, and i let out the clutch slowly, once it grabs, i let it out more till its fully out, and raise the throttle. I do do rolling shifts from time to time, but only when im hauling an empty wagon
#4 Tecumseh power OFFLINE
Tecumseh power
  • 1,464 Thanks
  • 1,104 posts
Posted May 14, 2017 - 12:57 AM
Mow in 2nd hi. Snow blow in 1st/2nd lo. Travel in 3 high. Plow garden in 2nd high.
#5 karel ONLINE
karel
  • 1,986 Thanks
  • 1,327 posts
Posted May 14, 2017 - 04:54 AM
I Have to get off and move the belt on the pully. Panzer's don't shift. They just pull.
#6 Alc ONLINE
  • 6,739 Thanks
  • 7,395 posts
Posted May 14, 2017 - 05:06 AM
I try not to shift the PK while moving never from 1st to 2nd but 2nd to 3rd with the foot throttle you can rev up in 2nd then let off between shifts even then I'm not good enough to get a perfect shift. The Jim Dandy with just a hand throttle never
#7 John Arsenault ONLINE
John Arsenault
  • 2,373 Thanks
  • 1,145 posts
Posted May 14, 2017 - 06:59 AM
Its a gear selector not a shifter, there are no syncro's in these trannys. Shifting them seems to me like a good way to mess up your gearbox.
So my answer is Nope with a capital N
  • Gtractor, pharmer, Cvans and 3 others have said thanks
#8 pharmer OFFLINE
pharmer
  • 871 Thanks
  • 774 posts
Posted May 14, 2017 - 07:18 AM
I agree. Maybe we do things different (correct) here in New England
Edited by pharmer, May 14, 2017 - 07:19 AM.
  • boyscout862 and Greasy6020 have said thanks
#9 MH81 OFFLINE
Posted May 14, 2017 - 07:20 AM
Yeah, what you said.
Except this spring, I've had to mow in 1L. Too many weeks of rain that wouldn't let me in there to mow and it was thigh high.
  • Tecumseh power and Greasy6020 have said thanks
#10 chieffan ONLINE
  • 9,540 Thanks
  • 6,399 posts
Posted May 14, 2017 - 07:23 AM
Only gear tractors I have are a couple Bolens and I never change gears while in motion.
  • Cvans, boyscout862 and Greasy6020 have said thanks
#11 larrybl ONLINE
larrybl
    Texas Member
  • Site Supporter
  • 6,856 Thanks
  • 4,348 posts
Posted May 14, 2017 - 07:39 AM
On the peerless with the Hi-Lo shifter, a complete stop is needed. On the 6 speed peerless I can get away with shifting from 6th to 5th and vice versa, but it does require careful de-clutching, and never force the shifter. (Similar to shifting a car with out clutching- light pressure on the shifter till it slides into gear)  I usually perform this maneuver 30-40 times per mowing due to the uneven growth of the grass. Then the other maneuver is when in 5th or 6th and I need to slow down for a sharp turn or obstacle I just slip the clutch.
  • Alc, Cvans and Greasy6020 have said thanks
#12 WNYTractorTinkerer ONLINE
WNYTractorTinkerer
    Tinker Master
  • 10,185 Thanks
  • 5,664 posts
Posted May 14, 2017 - 08:52 AM
I just put my foot down on the hydro..  I'm just shiftless!
  • KennyP, dropped82, SupplySergeant and 2 others have said thanks
#13 Jazz ONLINE
Jazz
  • 2,302 Thanks
  • 1,401 posts
Posted May 14, 2017 - 11:10 AM
Yes, stop to shift. How deep in the mud are you?
#14 glgrumpy ONLINE
  • 8,549 Thanks
  • 7,877 posts
Posted May 14, 2017 - 11:11 AM
Most belt clutches are a Go-No/Go on/off switch and grab and jerk. Can throttle down some may help. Have to learn each machine, all seem to have their own methods needed to drive.  I'm older, prefer hydro, but even them can be grabby some if hand levers used.  Haven't had one running yet with foot control.
#15 Bob E ONLINE
Bob E
  • 126 Thanks
  • 101 posts
Posted May 14, 2017 - 11:20 AM
I shift speeds on the go all the time without ever leaving my only forward gear  :D
Edited by Bob E, May 14, 2017 - 11:22 AM.
