Roller chain help
4 replies to this topic
#1 tek6029 OFFLINE
tek6029
  • 2 Thanks
  • 5 posts
Posted May 13, 2017 - 01:38 PM
Bought a Bolens 2028 rider, all it needs is a chain. Part of the old chain was with it, #40 roller chain.
Bought 10 feet of new stuff to make new one. Wrestled with all of it to spool it into the mower and measure. Did so, but now I've run into an issue trying to link it back together.
At the proper length, I come up with an outside Link on one end, and inside on the other, so I can't get the master to install right. Take 1 link out so I have an inside link on each end so I can install master properly, and it's too short. Add 2 links so it's a bit longer and I have my 2 inside links on each end, and it's too long and binds up.
Am I missing something? Is there a special chain I should be using? Am I not doing This right?
Grass is getting long and I'm getting discouraged...
Sent from my XT1585 using Tapatalk
  • Bolens 1000 said thank you
#2 Bill 76 ONLINE
Bill 76
  • 1,950 Thanks
  • 1,196 posts
Posted May 13, 2017 - 01:57 PM
Try using a half link and when the chain stretches take it out.
  • Bolens 1000, Alc, js5020 and 2 others have said thanks
#3 Bolens 1000 ONLINE
  • 14,989 Thanks
  • 18,141 posts
Posted May 13, 2017 - 04:41 PM
:ditto:  I'd suggest using a half link if your having trouble
#4 tek6029 OFFLINE
tek6029
  • 2 Thanks
  • 5 posts
Posted May 13, 2017 - 04:43 PM
I didn't know such a thing existed! Sounds like just what I need! Thanks!
#5 Bruce Dorsi ONLINE
Bruce Dorsi
    Old, but not dead -- yet!
  • 3,915 Thanks
  • 2,451 posts
Posted May 13, 2017 - 08:24 PM
The half-links are also known as an offset link by some companies.
Check to see if there is some adjustment to see if chain slack can be taken up or added.  If both sprockets are fixed and there is not an idler sprocket, then you will have to adjust length by adding or removing links.
If there is a sprocket idler, there may be an adjustment where it is mounted.
