Another "What do I Have"
montgomery ward tractors walk behind tractors
36 replies to this topic
#31 jimmy G ONLINE
jimmy G
  • 1,178 Thanks
  • 762 posts
Posted June 03, 2017 - 07:52 PM
3 1/2",2 3/4",2 1/4",secondary pulley is the driven pulley or tractor pulley,implement's are driven off the engine pulley if you're 5/8" pulley is on the tractor then it is for ground speed,ask as many questions as you like I live for this old iron lol,I am not however the smartest one here by a long ways and quite able at giving a wrong answer
#32 frankclrh2o OFFLINE
frankclrh2o
  • 12 Thanks
  • 22 posts
Posted June 04, 2017 - 09:34 PM
Thanks .  will do some more checking tommorrow. The 8 X5/8 pulley is on the tractor on the inside.Why are there three pulleys on the engine if the 8 inch pulley is for an attachment?  I think i can make it work and get two speeds by using the two outside pulleys on the engine and the secondary.  once i get the engine running that is what i will try.  thanks again for your help.
#33 jimmy G ONLINE
jimmy G
  • 1,178 Thanks
  • 762 posts
Posted June 05, 2017 - 01:12 AM
Both my driven pulleys are 5/8"(only two)and can be adjusted in or out,implement's are run off extra pulley on engine,there is a lot of difference between my SIM and your MID and this could make a difference on the engine pulley
  • frankclrh2o said thank you
#34 frankclrh2o OFFLINE
frankclrh2o
  • 12 Thanks
  • 22 posts
Posted October 12, 2017 - 02:26 PM
it has been awhile since i have been on the forum.  i have been through the tractor replaced bushings and seals.  painted and reassembled.  i was not able to get the engine started.  have not been able to find parts other than a carb.  i installed a Harbor freight engine on the tractor without changine the tractor so i can put the original engine on if i can get it running.  i need a throttle cable and lever for it.  i got one off of a Bolens tractor but it was mounted on the left handle.  mine is suppose to be mounted on the right handle.  does anyone know where i might find a throttle cable assembly similar to the oriinal.  is there any on who has a walk behind tractor salvage out there.  wild guesss question.  it hass been fun working on it and have been thankful for the help an comments i have recieved fron the forum.  would appreciate and help. thanks
#35 jimmy G ONLINE
jimmy G
  • 1,178 Thanks
  • 762 posts
Posted October 12, 2017 - 11:13 PM
Might do better in the wanted section for correct parts, till then run the Bolens cable, i would until the right part came along, the universal clamp on cables are a popular option for a later un-do
#36 frankclrh2o OFFLINE
frankclrh2o
  • 12 Thanks
  • 22 posts
Posted January 18, 2018 - 04:36 PM
It has been a while since i have been active on the forum  been working on the MW and also the following.
Friend gave me a Bolens walk behind tractor with a sickle mower.  Have been modifying the sickle mower to use on my Montgomery ward walk behind tractor.  have it pretty well done except i need new sections for it.  There are 15 sections on the bar.  They are 2 inch wide and 2 5/8 front to back.  they have 1 3/8 spacing on the rivet holes.  They may have been longer front to back as they are real worn and look like they  have been sharpened.  Any one have a suggestion where i might find new sections.  Thanks for any help.
#37 frankclrh2o OFFLINE
frankclrh2o
  • 12 Thanks
  • 22 posts
Posted January 18, 2018 - 04:37 PM
the only number i have found on the mower is "Type No. AB02A01"
