Sealed Bearing in Deck
8 replies to this topic
#1 bbuckler ONLINE
bbuckler
  • 3,316 Thanks
  • 2,974 posts
Posted May 11, 2017 - 09:00 PM
I still can't find bearing seals for the sears deck so I was wondering as anyone tried sealed bearings ?
#2 MH81 OFFLINE
Posted May 11, 2017 - 11:48 PM
What deck again?
  • KennyP and bbuckler have said thanks
#3 John Arsenault ONLINE
John Arsenault
  • 2,371 Thanks
  • 1,144 posts
Posted May 12, 2017 - 05:53 AM
When I opened mine up they had tapered bearing in there.
http://www.searspart...47/0709000.html
  • bbuckler said thank you
#4 chieffan ONLINE
  • 9,532 Thanks
  • 6,397 posts
Posted May 12, 2017 - 07:00 AM
Check with BAUM HYDRAULICS web site.  You will need the size (id and od) to find the one you need.  Probably won't cross over a Crapsman number.
#5 KennyP ONLINE
  • 37,400 Thanks
  • 45,453 posts
Posted May 12, 2017 - 07:16 AM
Hard to find a part number without a deck model anyway.
#6 bbuckler ONLINE
bbuckler
  • 3,316 Thanks
  • 2,974 posts
Posted May 14, 2017 - 05:40 PM
Sorry guy I been busy the last few days. I got the part number which is 822R it shows NLA everywhere with it. It a 1-9/16 OD and the center hole is 3/4
Edited by bbuckler, May 14, 2017 - 05:42 PM.
#7 KennyP ONLINE
  • 37,400 Thanks
  • 45,453 posts
Posted May 14, 2017 - 06:00 PM
A good bearing supply can match it!
#8 bbuckler ONLINE
bbuckler
  • 3,316 Thanks
  • 2,974 posts
Posted May 14, 2017 - 06:05 PM
Can't  find a good one local I might get uncle to look in Ohio since he coming down in a few weeks
#9 pdulaff OFFLINE
pdulaff
  • 2 Thanks
  • 1 posts
Posted May 15, 2017 - 08:11 AM
I checked the Timken seal cross refernce for a 0.750 shaft dia X 1.561 O.D. bore size, 1.565 seal O.D.   An off the shelf seal P/N 450340 exists which is 0.375 thick using Nitrile seal material. It is a lip seal with a garter spring. Comes up available from Advanced Auto and other sources.
  • bbuckler and John Arsenault have said thanks
