Oil Leakage at axles of 7 speed 918-04566 transmission assembly
2 replies to this topic
#1 560Dennis OFFLINE
560Dennis
  • 11 Thanks
  • 20 posts
Posted May 09, 2017 - 07:36 PM
I looked over the manual and did not see oil recommendation type, weight , ?
So I look at the transmission briefly did not see a fill or drain.
I don't know how long they both have been leaking .
Is there seal in the gear box ?
How do I check ?
How long will this go before it locks up. I think the forward and reverse shift Rod is hanging up , which cause the Transmission stay in neutral when it in forward or reverse . Had to rock the tractor back forth to get it to goin into gear
#2 637Yeoman OFFLINE
637Yeoman
  • 1,551 Thanks
  • 1,254 posts
Posted May 09, 2017 - 08:11 PM
Im thinking that, like a lot of new transaxles, you cant fill them. If you want to, you will have to unbolt the two halves, and fill that way. Such a pain in the behind.
#3 560Dennis OFFLINE
560Dennis
  • 11 Thanks
  • 20 posts
Posted May 09, 2017 - 08:21 PM
Ouch that hurts . That tractor beat me up today with all the things I had to discover to get it mowing again . Not just tractor wouldn't go forward or backwards . But it started , had it stuck in the ditch ,had to P use it to the garage to fix ,catch my breath the take the deck out look see why it wasn't moving UGH ,
Edited by 560Dennis, May 09, 2017 - 08:24 PM.
  • 637Yeoman said thank you
