Looking for Brigs Exhaust valve 390420, and a question
9 replies to this topic
#1 larrybl OFFLINE
larrybl
    Texas Member
  • Site Supporter
  • 6,760 Thanks
  • 4,303 posts
Posted May 09, 2017 - 07:10 PM
I need Two Exhaust valve 390420 for my 422437 1209 01 engine. NLA everywhere, but I found this.
http://www.ebay.com/...qsAAOSw9N1VkUIW
Will these work?
#2 classic ONLINE
classic
  • 4,945 Thanks
  • 2,173 posts
Posted May 09, 2017 - 08:22 PM
There are original valves available on ebay.
http://www.ebay.com/...feea3%7Ciid%3A3
Edited by classic, May 09, 2017 - 08:35 PM.
#3 Bolens 1000 ONLINE
  • 14,809 Thanks
  • 18,054 posts
Posted May 09, 2017 - 08:26 PM
I can order them for you, if interested just send me a PM
  • larrybl said thank you
#4 larrybl OFFLINE
larrybl
    Texas Member
  • Site Supporter
  • 6,760 Thanks
  • 4,303 posts
Posted May 09, 2017 - 09:03 PM
PM sent.
#5 larrybl OFFLINE
larrybl
    Texas Member
  • Site Supporter
  • 6,760 Thanks
  • 4,303 posts
Posted May 09, 2017 - 09:08 PM
Those are listed as "used". Mine are "Used" also. To adjust these the stem needs to be carefully ground and polished to meet the specifications. I prefer new or new subistutes for my situation.
#6 classic ONLINE
classic
  • 4,945 Thanks
  • 2,173 posts
Posted May 09, 2017 - 10:06 PM
I've seen NOS valves listed as used because the boxes have shelf wear. It would be something to clarify with the seller before purchasing. I just listed that valve to show that what you need is still available through ebay. There are others listed with that same part number and others listed under the part number that supersedes 390420. Sometimes Briggs valves can have different part numbers for the same valve. You just have to make sure that a valve with a superseded part number takes the same keepers. I've run into two different types of keepers on the Briggs 23ci engines. I didn't think that you were looking for used valves, since you said that you needed new valves. Like I was saying, I would have asked that seller on ebay if they were actually used or just listed that way due to shelf wear. I've purchased many NOS parts listed as used due to shelf wear, since it would be far too costly for me to pay retail for a complete engine rebuild with NOS parts. It's just how it is when building multiple engines for multiple restoration projects. Well it looks like Bolens 1000 has you hooked up with new valves and that can save you some possible ebay grief.
#7 Bruce Dorsi OFFLINE
Bruce Dorsi
    Old, but not dead -- yet!
  • 3,906 Thanks
  • 2,448 posts
Posted May 10, 2017 - 07:42 AM
One needs to be careful when purchasing "new" valves from ebay, or an unknown source.
The valve may have been ground for clearance, and when it was realized that too much of the stem was removed because the lifter was partially raised, the new valve was put back in the box before being lapped, and re-sold.
Of course, it will look like new, and it has never been used (run), so in the seller's mind it is still "new."
#8 KennyP OFFLINE
  • 36,529 Thanks
  • 44,977 posts
Posted May 10, 2017 - 07:53 AM
If you haven't found the valves, I'll check the 2 engines I have here with bad cranks. Might be able to pull a pair out and get you fixed up.
#9 larrybl OFFLINE
larrybl
    Texas Member
  • Site Supporter
  • 6,760 Thanks
  • 4,303 posts
Posted May 10, 2017 - 07:06 PM
Thanks Kenny, I ordered the exhaust valves from ebay, they are Stens 505-044. The rest I ordered from partsandservice.com
not sure which engine I'll put them in yet. Probably the spare as it has the fewest hours after the initial rebuild.
#10 larrybl OFFLINE
larrybl
    Texas Member
  • Site Supporter
  • 6,760 Thanks
  • 4,303 posts
Posted May 11, 2017 - 09:44 PM
Well this Sux
New message from: ira114 iconTopRatedSeller_19x18.png(11,537stars-11.gif)
Hey, I went to order the item and found out that this item is no longer made.
I will be cancelling the order now.
Sorry, Ben
See the full issue here. http://gardentractor...-refresh/page-8
This is a dead thread now.
