Foote 3864
3 replies to this topic
#1 Macmagee OFFLINE
Macmagee
  • 30 Thanks
  • 67 posts
Posted May 09, 2017 - 01:18 PM
Took the trans out of the tractor and found out it was a foote 3864 with 3/4 inch axels question can I upgrade to 1 inch axels? Or what is a direct heavier duty replacement? Does anyone have any spider gears laying around trying to lock the rear do not like to weld the gears .
#2 boyscout862 ONLINE
  • 12,869 Thanks
  • 9,180 posts
Posted May 09, 2017 - 01:45 PM
What tractor?  Those transaxles are not always interchangeable. Take the old one out and try to match it to what you want. If you were to use an old Bolens, their rear ends are designed to be tightened so that there is no slip. Good Luck, Rick
  • Macmagee said thank you
#3 Macmagee OFFLINE
Macmagee
  • 30 Thanks
  • 67 posts
Posted May 09, 2017 - 01:52 PM
Murray 1988
#4 637Yeoman OFFLINE
637Yeoman
  • 1,551 Thanks
  • 1,254 posts
Posted May 09, 2017 - 02:41 PM
I would think you couldnt change them, and with that light of a tractor, you will loose traction before you snap an axle.
