Oil change FAIL!
25 replies to this topic
#1 larrybl ONLINE
larrybl
    Texas Member
  • Site Supporter
  • 7,011 Thanks
  • 4,418 posts
Posted May 08, 2017 - 05:21 PM
Finished mowing the back yard, and decided to change the oil while it was hot. Everything going fine except instead of the end cap coming off, the whole oil drain came out. There was no stopping the Exxon Valdez flood, at least it was on the ramp. And to add insult to injury, I lowered RED and pushed him off the ramp. I  got in a hurry to rinse the oil off before too much staining and went to move RED and cranked him up, It took 10 seconds for my brain to register I had not added oil yet and shut him down. Well, new oil and he still sounds fine. I hope I dodged a bullet this time.
  • MH81, hamman, KennyP and 7 others have said thanks
#2 KennyP ONLINE
  • 38,510 Thanks
  • 45,987 posts
Posted May 08, 2017 - 05:37 PM
Don't tighten the cap so hard next time!
  • larrybl, hamman and 637Yeoman have said thanks
#3 larrybl ONLINE
larrybl
    Texas Member
  • Site Supporter
  • 7,011 Thanks
  • 4,418 posts
Posted May 08, 2017 - 05:42 PM
Never happened before, no way to hold the pipe with a pipe wrench. I'll be adding a 90* angle to the end of the pipe next oil change. Problem solved!
  • MH81, hamman and ericjr16 have said thanks
#4 classic ONLINE
classic
  • 5,209 Thanks
  • 2,248 posts
Posted May 08, 2017 - 05:58 PM
I left the dip stick out on a Cub Cadet and it was like Old Faithful (in Texas) when I started it, HA! These things happen, especially if we're in a rush. I remember when a guy thought he could move Kawasaki 115 loader about 30 feet after dumping the oil and changing the filters. He just had to start it quick and back it up to reach the oil fill hose. Well I don't think it went 10 feet. It was one of these.
  • larrybl, MH81, Cvans and 1 other said thanks
#5 ericjr16 ONLINE
ericjr16
  • 1,051 Thanks
  • 575 posts
Been there done that! Glad you remembered oil, um I didn't! It seized on me. Thank God it was old flat head. After some oil in cylinder and prayers, it's still running!
  • larrybl and propane1 have said thanks
#6 KennyP ONLINE
  • 38,510 Thanks
  • 45,987 posts
Posted May 08, 2017 - 06:11 PM
At least it's still running! Better than I can say about the management here!
  • wilberj, larrybl, MH81 and 2 others have said thanks
#7 KC9KAS ONLINE
KC9KAS
  • 5,391 Thanks
  • 4,693 posts
Posted May 08, 2017 - 06:13 PM
I have seen advertisements for "Slick 50" and you can drain the Slick 50 and run the engine without oil!
Yeah, right!
  • larrybl said thank you
#8 larrybl ONLINE
larrybl
    Texas Member
  • Site Supporter
  • 7,011 Thanks
  • 4,418 posts
Posted May 08, 2017 - 06:25 PM
In my younger days I had a bright idea of draining the oil on a push mower engine I had mounted in the garage to tinker with. I filled the crankcase with liquid soap, and figured if I run the engine, It will make the teardown not as messy. Can't remember if it damaged the engine (it ran afterwards) but I do remember a frothy ball of foam engulfing the engine and making a bigger mess than I anticipated.
  • KennyP, Cvans and classic have said thanks
#9 Xrperry ONLINE
Xrperry
  • 1,036 Thanks
  • 769 posts
Posted May 08, 2017 - 08:02 PM
Long ago I changed the oil in one of my rigs,forgot to put drain plug back in,5 quarts of oil on the floor lol.crap happens
#10 EricFromPa ONLINE
EricFromPa
  • 3,672 Thanks
  • 3,118 posts
Posted May 08, 2017 - 08:16 PM
Nothing worse than dumping about 7 quarts of water laden gear oil out of a big drain pan all over your shed floor. Man that stuff makes a heck of a sticky smelly mess especially inside a small 10x10 shed like mine..I should spill more on the floor Keeps the critters out of the shed for a good while.Darn chipmunks been in the shed chewing stuff again.
#11 larrybl ONLINE
larrybl
    Texas Member
  • Site Supporter
  • 7,011 Thanks
  • 4,418 posts
Posted May 08, 2017 - 08:17 PM
This is the plan for the next oil change. Won't prevent the oops on the drain plug, but will prevent spinning the pipe out of the block.
  • karel and ericjr16 have said thanks
#12 petrj6 OFFLINE
petrj6
  • 4,083 Thanks
  • 2,369 posts
Posted May 08, 2017 - 08:39 PM
not to point out the obvious but why didn't you just put the pipe back in or STOP when you saw they both were turning.  kid a work a few years back turned a barrel of oil on its side then took the plug out, then fiddle around trying to put the bung back in while oil ran all over everywhere!!!  worst part is was on one of those flip carts so I walked by and just stood it back up with one hand!!!!  Kid stood there staring in amazement, it happens to everyone.
        Pete
  • larrybl and karel have said thanks
#13 EricFromPa ONLINE
EricFromPa
  • 3,672 Thanks
  • 3,118 posts
Posted May 08, 2017 - 09:08 PM
I put a valve on one of my old tractors with a hunk of clear hose zip tied on the nipple.Forget what engine I snagged it off of but it was like this valve.It was pretty slick.
Oh I remember where I got it. It was on a blown up Kawasaki in a 1980s JD 165 Lawn Tractor.
#14 larrybl ONLINE
larrybl
    Texas Member
  • Site Supporter
  • 7,011 Thanks
  • 4,418 posts
Posted May 08, 2017 - 09:09 PM
        Pete
Well I decided to change the oil right after mowing 1.5 acres. I did not know the pipe was turning, I thought the cap was. The catch pan and funnel was positioned under the end of the pipe. When the tube came out it was too hot to handle, and the pan / funnel wouldn't fit under the frame where the oil was spewing from. Due to the HOT nature of the oil it only took 3 seconds to drain.
  • petrj6, ericjr16 and propane1 have said thanks
#15 MH81 OFFLINE
Posted May 08, 2017 - 10:02 PM
Took 3 seconds, felt like 3hours of slo mo.
Been there, have the oily palm print on my forehead
  • Cvans, ericjr16 and John Arsenault have said thanks
