Solid-State Conversion?
magneto/condenser/points
5 replies to this topic
#1 Charles Ruge OFFLINE
Charles Ruge
  • 1 posts
Posted May 08, 2017 - 04:47 PM
No spark in a Briggs & Stratton Model 243431 0123 Type 01 CC: 67100 61, in an Allis-Chalmers B-110 garden tractor. Can I convert that motor model to solid-state ignition? Would I need to get the flywheel re-polarized?
#2 DougT OFFLINE
DougT
    Dog Approved
  • 8371 Thanks
  • 5753 posts
Posted May 08, 2017 - 05:03 PM
Welcome to the forum. My understanding is if it has 2 magnets on the flywheel it would have to be repolarized. If the coil is good, you could convert it with one of the electronic modules that eliminates points and condenser.
  • Bolens 1000 and boyscout862 have said thanks
#3 boyscout862 OFFLINE
  • 15196 Thanks
  • 10000 posts
Posted May 08, 2017 - 05:20 PM
Welcome to GTT. Go to our Manuals Section and download the B&S manual for your engine. It should help. The points box on those engines will fill with oil, shorting out everything. You can replace the plunger and/or install a seal kit. One of our sponsors carries the parts. Good Luck, Rick
#4 Dayton_King ONLINE
Dayton_King
  • 1812 Thanks
  • 1288 posts
Posted May 08, 2017 - 08:50 PM
Actaully the new magnetron mags you don't need to repolarize. Zippo on YouTube shows a video with it installed
#5 EricFromPa OFFLINE
EricFromPa
    Fixer of Broken junk
  • 6773 Thanks
  • 4562 posts
Posted May 08, 2017 - 08:53 PM
Can't use the multi magnet flywheels with a Magnetron coil or a Nova 2 or Mega-Fire module even if you have it repolerized. They fire Way Way to advanced. It will either instantly sheer the flywheel key or backfire through the carb with a big ole fireball.
Single magnet flywheels can be repolerized. If you have a Compass handy try this.
To determine whether or not your flywheel is magnetron ready, offer a compass to the center fin of the aluminum magnet carrier on the flywheel. If north points toward the flywheel, it has not been re-polarized and is not magnetron ready. If south points toward the flywheel, it has been re-polarized and is magnetron ready.
If you have to have your flywheel reploerized Briggs does it Free of charge.Just ship your flywheel with a small note describing that you would like to have your flywheel reploerized. I've had 3 reploerized. Address is as foillows.
Briggs and Stratton Corp.
Menomonee Falls Distribution Center
Flywheel Repolarization
N83 W12529 Old Orchard Rd.
Menomonee Falls, WI 53051 2272
#6 DougT OFFLINE
DougT
    Dog Approved
  • 8371 Thanks
  • 5753 posts
Posted May 09, 2017 - 05:53 AM
So......Should I take the Nova modules off the ones that I have running them?? They really seem to run pretty good and no sheared keys yet. The only ones that I can't get to run right on them are the magnamatic systems.
