I'm an Ingersoll Child
41 replies to this topic
#31 LilysDad ONLINE
LilysDad
    Millennium Falcon
  • 12,640 Thanks
  • 9,449 posts
Posted May 27, 2017 - 12:05 PM
I've got this photo tach that has worked real well on my other engines. I went to use it on the Ingersoll. The flywheel screen is covered by the shroud. The only thing available is the pto and it has to be on to check that end, which slows the engine down an unknown amount with the mower in gear. I even checked the flywheel shroud/engine cover in hopes there might be some kind of removeable plate. Nope!.
Edited by LilysDad, May 27, 2017 - 12:05 PM.
#32 Cat385B OFFLINE
    HAZMAT CAT
  • 13,533 Thanks
  • 9,826 posts
Posted May 27, 2017 - 12:51 PM
With the throttle lever in the rabbit position, I can tell from here it's running W-AO.
#33 dropped82 ONLINE
dropped82
    Nut Case
  • 2,318 Thanks
  • 1,736 posts
Posted May 27, 2017 - 01:25 PM
What if you remove the deck drive belt. That way there is no load on the engine when the pto is engaged.
Eric
  • LilysDad said thank you
#34 LilysDad ONLINE
LilysDad
    Millennium Falcon
  • 12,640 Thanks
  • 9,449 posts
Posted May 27, 2017 - 01:47 PM
That's a thought!
  • dropped82 said thank you
#35 LilysDad ONLINE
LilysDad
    Millennium Falcon
  • 12,640 Thanks
  • 9,449 posts
Posted May 27, 2017 - 01:49 PM
Would that be W-AO at 2800 or at 4000? Would turtle be 850 or 1100?
#36 gopher OFFLINE
gopher
  • 749 Thanks
  • 752 posts
Posted May 28, 2017 - 11:03 PM
You should be able to stick tape right on the curve of washer on front of elec pto. The pto does not need to be on center is crankshaft.
Edited by gopher, May 28, 2017 - 11:15 PM.
#37 LilysDad ONLINE
LilysDad
    Millennium Falcon
  • 12,640 Thanks
  • 9,449 posts
Posted June 01, 2017 - 06:46 AM
Silly me! It finally occurred to my little brain to take the grille off the right side of the steering tower and reach in to put the tape on the stub shaft coming off the flywheel.
#38 BowlBuilder OFFLINE
BowlBuilder
  • 484 Thanks
  • 465 posts
Posted June 09, 2017 - 05:09 PM
Eastman turned over its parts distribution to CPD (Central Parts Distributors) a while back. This has resulted in cheaper parts, some substantially. Belts are now half of what they used to be. Many previously unavailable parts are now being reproduced again. Eastman is no longer in business and is for sale. All of their production equipment and machinery now sits somewhere in trailers hoping to find a buyer (not likely). Owner has had major health problems for years which eventually lead to the demise of his business. I too would recommend Brian Hildreth for parts. Great person to deal with.His website: https://salempwr.com/
For used parts and accessories I would contact Dan Haas at: (810) 348-6311 I've never purchased from him myself, but have heard good things from many people.
#39 BowlBuilder OFFLINE
BowlBuilder
  • 484 Thanks
  • 465 posts
Posted June 09, 2017 - 05:19 PM
On a side note, I believe the factory blades are noticeably thicker and heavier than aftermarket blades. Also the belts are 5/8" wide and top quality. Not a real common width. 1/2" or 3/4" will not fit the pulley grooves properly and may fail prematurely.
#40 LilysDad ONLINE
LilysDad
    Millennium Falcon
  • 12,640 Thanks
  • 9,449 posts
Posted June 09, 2017 - 08:41 PM
Thanks! I need a crank handle for a SB48 Ingersoll snow caster.
#41 BowlBuilder OFFLINE
BowlBuilder
  • 484 Thanks
  • 465 posts
Posted June 10, 2017 - 03:16 AM
He has what may be the largest collection of Case/Ingersoll tractors and parts anywhere. Here is his Craigslist ad. I have no idea where he gets them all.
https://detroit.crai...6127890779.html
#42 BowlBuilder OFFLINE
BowlBuilder
  • 484 Thanks
  • 465 posts
Posted June 10, 2017 - 03:24 AM
You may also try a gentleman named Brett. He also has a very large collection which is very well organized. I have had no personal dealings with either.
https://racine.craig...6105941291.html
