1967 Wizard 10hp
9 replies to this topic
#1 Dayton_King ONLINE
Dayton_King
  • 1,456 Thanks
  • 1,143 posts
Posted May 07, 2017 - 05:21 PM
I believe this is a 1967 Wizard. Engine prefix is a D. Kohler k241 I need a gas tank and to rewire. The biggest issue is the steering gears are stripped. Any sources for good ones? Also no gas tank
  • boyscout862, HANKG and Montgomeryluv15 have said thanks
#2 HANKG ONLINE
HANKG
  • 6,536 Thanks
  • 3,505 posts
Posted May 07, 2017 - 05:32 PM
Cool machine maybe our sponsors can help with those parts.
#3 Montgomeryluv15 OFFLINE
Montgomeryluv15
  • 47 Thanks
  • 67 posts
Posted May 07, 2017 - 06:44 PM
I'll look around. Check out this page! I spotted 3 Wizards. PM them and see if they have that model. https://www.facebook...mowergraveyard/
#4 Dayton_King ONLINE
Dayton_King
  • 1,456 Thanks
  • 1,143 posts
Posted May 07, 2017 - 06:54 PM
I had bad luck and poor customer service with them. I prefer person to person
#5 karel OFFLINE
karel
  • 2,224 Thanks
  • 1,441 posts
Posted May 07, 2017 - 07:20 PM
 Junk yards are like that.
  • Dayton_King said thank you
#6 glgrumpy OFFLINE
  • 8,704 Thanks
  • 7,971 posts
Posted May 07, 2017 - 07:41 PM
That's cool!  Must be Gilson then with numbers like that?  Probly easier to find Gilson, than Wizard I bet.  Can you say "Fabrication", heh!  Might just see if the steering shaft might just need a spacer or washer to push it up or down as needed and be tighter?  PIA to get shaft out, and gears usally welded on to them, makes it hard to fix.
  • boyscout862 and Dayton_King have said thanks
#7 Dayton_King ONLINE
Dayton_King
  • 1,456 Thanks
  • 1,143 posts
Posted May 07, 2017 - 07:55 PM
I agree. If I can use a washer I can get the teeth to mesh better
#8 boyscout862 OFFLINE
  • 13,428 Thanks
  • 9,379 posts
Posted May 08, 2017 - 09:16 AM
Check through our Manuals Section for info on what you need. I was looking at a Gilson last year that had a 12 hp B&S castiron engine. It had a very different hood and grill but the rest may have been the same. You should look for a parts machine. Good Luck, Rick
#9 Dayton_King ONLINE
Dayton_King
  • 1,456 Thanks
  • 1,143 posts
Posted May 08, 2017 - 08:12 PM
#10 Dayton_King ONLINE
Dayton_King
  • 1,456 Thanks
  • 1,143 posts
Posted May 08, 2017 - 08:13 PM
All I need is a gas tank. I will rewire it, and do a bunch of small stuff.
