Eaton 11 Hydro fluid, filter
6 replies to this topic
#1 hfm0323 OFFLINE
hfm0323
  • 2 Thanks
  • 17 posts
Posted June 14, 2011 - 07:01 PM
Picked up a 78 H16XL to pull the tiller, ran well enough to load. Carbs soaking and kit ordered. Tested compression at 150lb, wasn't expecting it to be that high but checked it twice. Anyone know what range these tecumseh's oh160's normally run?
The trans. fluid is on the low side, manual says SAE 20wt. Auto store didn't have any, before I search all over thought I'd ask the experts if you have other recommendations that may be better and or more readily available. While I'm at it, the filter Bolens #1726450, can this be cross referenced with a commonly available line? Any suggestions are appreciated, hope to have it back in use soon.
Thanks
#2 mikebramel OFFLINE
mikebramel
    Ron Paul
  • 177 Thanks
  • 1,009 posts
Posted June 14, 2011 - 10:48 PM
Wix 51410
  • hfm0323 said thank you
#3 hfm0323 OFFLINE
hfm0323
  • 2 Thanks
  • 17 posts
Posted June 17, 2011 - 08:29 AM
Great, looks like O'reilly's can get that. Off to a good start.
#4 ducky OFFLINE
  • 1,982 Thanks
  • 4,103 posts
Posted June 17, 2011 - 09:07 AM
I use Tractor/Hydraulic fluid spec # JDM J20C in my Eatons and Sunstrands. Good EP quality and no foaming. Can be had at Tractor Supply.
#5 hfm0323 OFFLINE
hfm0323
  • 2 Thanks
  • 17 posts
Posted June 17, 2011 - 04:02 PM
Just what I needed to know, I'm one step closer.
#6 NUTNDUN OFFLINE
  • 10,340 Thanks
Posted June 17, 2011 - 05:26 PM
150psi is great compression. I don't think you have anything to worry about with that.
#7 hfm0323 OFFLINE
hfm0323
  • 2 Thanks
  • 17 posts
Posted June 23, 2011 - 04:52 PM
Ok, I ordered the wrong carb. kit, guess I was so excited I got in a hurry. Hope to have everything available to put it back together this weekend. Thanks for all the good input.
