Road trip, blades
11 replies to this topic
#1 glgrumpy OFFLINE
  • 9122 Thanks
  • 8205 posts
Posted May 06, 2017 - 03:57 PM
Went to buy blade, came home with two. Have G14. This blade fit?
Model 30242 Serial 0202695
19 x 42", it's tall for sure I don't have lift rod, what they look like? Thinking lift arm bent down lower. Upper bend seems right. So, need to bend till small bend is vertical?
These feet missing a part?
#2 Mtypython OFFLINE
Mtypython
  • 415 Thanks
  • 378 posts
Posted May 06, 2017 - 06:25 PM
will send you a pic of mine on my 1053,with the rod ..should fit the 14
#3 Dave in NY OFFLINE
Dave in NY
  • 2638 Thanks
  • 925 posts
Posted May 06, 2017 - 07:27 PM
It ought to fit. The skid shoes look normal. Looks like the arm that the lift link attaches to might indeed be tweaked a bit. Could have been from rough handling. If so, a block of hard wood and a heavy hammer ought to persuade it back into place without much trouble. Good find!
#4 glgrumpy OFFLINE
  • 9122 Thanks
  • 8205 posts
Posted May 06, 2017 - 07:41 PM
Moved it over to tractor tonight. Seems mount spacing is wrong, UNLESS there is more little lock links or ???  The space on the blade is just a little too small to fit into the tabs on axle, and yet, not big enough to go outside either.  I measured my G9 and it seems the same, might be same axle even.  These DO go on the axle correct?? Guess I better look in the Manuals and see what is there.
#5 Oldford OFFLINE
Oldford
  • 1135 Thanks
  • 786 posts
Posted May 06, 2017 - 07:43 PM
The green blade is off an Eliminator 1980s w/manual lift...
#6 chieffan OFFLINE
  • 16594 Thanks
  • 9088 posts
Posted May 06, 2017 - 07:53 PM
Fits Medium frame or XL series tractors with manual lift.  Hydraulic lift has the lift bar under the belly.
#7 glgrumpy OFFLINE
  • 9122 Thanks
  • 8205 posts
Posted May 06, 2017 - 08:14 PM
OH, Man! Now I have to buy another Bolen's just so blade has a place to fit!!  NOPE! Reworking this thing for the G models I have now. Original, so who cares on junkers anyway!   :smilewink: :poke: :(
  • CanadianHobbyFarmer said thank you
#8 blackjackjakexxix OFFLINE
blackjackjakexxix
    Blackjackjakexxix
  • 3726 Thanks
  • 2367 posts
It's for the ST tractors
  • ClassicBolens and 29 Chev have said thanks
#9 ClassicBolens OFFLINE
ClassicBolens
  • 1527 Thanks
  • 516 posts
Posted May 06, 2017 - 10:51 PM
Yep, fits ST Series.
  • 29 Chev said thank you
#10 glgrumpy OFFLINE
  • 9122 Thanks
  • 8205 posts
Posted May 07, 2017 - 11:45 AM
Don't know what ST means, but printed all the blade manuals for 42" on site and think the tube frame one looks closest. They have the big left bar on it. Difference is in the way it mounts to axle. MOst have metal tabs on both sides of the axle mount and pins. Think if I use, will spread what is there now, add that extra tab and pin same way. A lift rod and should go. The lift bar also in same manual looks like just heavy flat stock, but has a slot for floating I see and couple places in back by lever to pin? I did not see my actual model of blade in the manuals section. All seem like same or similar blade section and only the mounting section is diff on the older ones.
#11 ClassicBolens OFFLINE
ClassicBolens
  • 1527 Thanks
  • 516 posts
Posted May 08, 2017 - 09:23 AM
The "ST" series is the smaller lawn tractors that Bolens offered from 1984 thru the mid 90's that had a vertical shaft engine, suche as the ST110, ST110 etc. The blade itself is the same as the original 42" Tube Frame blade. Only the hitch is different. The hitch is very close in size and quite similar and should be easy enough to modify and adapt to your G14.
  • wilberj and 29 Chev have said thanks
#12 glgrumpy OFFLINE
  • 9122 Thanks
  • 8205 posts
Posted May 17, 2017 - 05:30 PM
Found diff blade at show, seems right mount and lift bar.
  • ClassicBolens said thank you
