Had my "here's your sign" moment today.
15 replies to this topic
#1 ol' stonebreaker OFFLINE
ol' stonebreaker
  • Validating
  • 1,688 Thanks
  • 1,148 posts
Posted May 05, 2017 - 10:13 PM
  Mowed around the edges of a friends yard today with my old Wizard and it had lots of tall, lush grass. When I got everything back home I looked under the deck to see how much was stuck to it. Lo and behold I noticed when I put the new blade in along with the new engine I installed the blade upside down. I'll bet it will cut lots better next time!!
                                     Mike
  • Alc, Delmar, Cvans and 15 others have said thanks
#2 Cvans ONLINE
  • 6,008 Thanks
  • 5,871 posts
Posted May 05, 2017 - 10:15 PM
You don't want to impress them too much the first time, they will think your showing off.   :smilewink:
  • KennyP, CRFarnsworth, tiretrx and 5 others have said thanks
#3 classic ONLINE
classic
  • 4,832 Thanks
  • 2,128 posts
Posted May 05, 2017 - 10:51 PM
Hope the grass isn't standing back up in the morning. I put the twist in the deck drive belt the wrong way on my old Simplicity one time. I knew the blades were sharp, so after beating up the grass on the first pass, I realized what I did.
  • Delmar, boyscout862, holdenboy1960 and 2 others have said thanks
#4 Little Irish Men OFFLINE
Little Irish Men
  • 808 Thanks
  • 465 posts
Posted May 06, 2017 - 12:41 AM
bin there done that,
Patrick.
  • chieffan said thank you
#5 old coot OFFLINE
old coot
  • 86 Thanks
  • 72 posts
Posted May 06, 2017 - 03:19 AM
so far i haven't done that but there's always the first time and the older i get i think that time may be coming up.....lol
  • Alc, oldedeeres, holdenboy1960 and 1 other said thanks
#6 chieffan OFFLINE
  • 8,802 Thanks
  • 6,035 posts
Posted May 06, 2017 - 06:59 AM
Reminds me when working construction.  Guy running the power hand saw said the blade needed touching up. When he finished he cut another board and said "Boy that works a lot better".  One of the other guys said "Will work better yet if you turn the blade around" !
  • KennyP, oldedeeres and holdenboy1960 have said thanks
#7 chieffan OFFLINE
  • 8,802 Thanks
  • 6,035 posts
Posted May 06, 2017 - 07:00 AM
Ever put an engine back in a tractor and bolt it down only to find you have to hook the starter cable up first?  I only did that once.
#8 shorty ONLINE
shorty
  • 4,779 Thanks
  • 4,882 posts
Posted May 06, 2017 - 07:02 AM
Been there done that. Couldn't believe I was that absent minded when I put it together.
#9 secondtry ONLINE
secondtry
  • 1,276 Thanks
  • 1,040 posts
Posted May 06, 2017 - 09:58 AM
   And that is why, when I catch my self starting to hurry I quit and go back in the house. Don
  • oldedeeres said thank you
#10 ol' stonebreaker OFFLINE
ol' stonebreaker
  • Validating
  • 1,688 Thanks
  • 1,148 posts
Posted May 06, 2017 - 01:26 PM
  In my case there was no hurry since there was still 2 ft of snow on the ground, LOL!!
                                        Mike
  • MH81 and holdenboy1960 have said thanks
#11 KC9KAS ONLINE
KC9KAS
  • 5,203 Thanks
  • 4,587 posts
Posted May 06, 2017 - 02:23 PM
I watched a guy try drilling through his floor-board to mount some type of radio.
He had a 1/2" drill and worked for half an hour and never got through the metal.
I watched a little bit then suggested switching the drill from reverse to FORWARD!
Didn't long at all to drill the holes after that!
  • KennyP, tractorgarden, oldedeeres and 1 other said thanks
#12 oldedeeres OFFLINE
oldedeeres
  • 8,271 Thanks
  • 4,258 posts
Posted May 06, 2017 - 03:13 PM
We had a friend once who hated to tell someone "no" when asked to do a favour. When he felt someone was taking advantage of his good nature he'd do a poor job and that usually solved the problem. It was hard on his pride to do less than his best though.
  • KennyP, Bill 76, ssmewing and 1 other said thanks
#13 ol' stonebreaker OFFLINE
ol' stonebreaker
  • Validating
  • 1,688 Thanks
  • 1,148 posts
Posted May 06, 2017 - 09:18 PM
  Years ago I walked in the toolhouse and my boss was trying to drill a hole through a piece of steel. He said he wished the mechanic, which was me, would sharpen the bits. I calmly said it would cut better if he ran the drill the right direction, got the tool i came for and walked out.
        Mike
  • KennyP and holdenboy1960 have said thanks
#14 old coot OFFLINE
old coot
  • 86 Thanks
  • 72 posts
Posted May 08, 2017 - 04:00 AM
that's funny ...reminds me of when I first got out of high school . I worked in a local garage and watched another mechanic do the same thing ,he was drilling a half inch hole thru metal plate  in reverse  only thing is he did get the hole drilled  took a bit longer than it should have but darn if he didn't get thru that plate  of course he was cussing ,sweating and blaming the bit
  • oldedeeres and holdenboy1960 have said thanks
#15 637Yeoman OFFLINE
637Yeoman
  • 1,548 Thanks
  • 1,254 posts
Posted May 08, 2017 - 12:29 PM
Hate when that happens. i mowed a whole yard once like that, thought something was iffy, but just kept going. Had to mow it again  :D
  • classic said thank you
