Repower Bolens 800
18 replies to this topic
#1 Jooohan87 OFFLINE
Jooohan87
  • 11 Thanks
  • 22 posts
Posted May 03, 2017 - 02:37 AM
Hello.
Anyone repowered a 800/900/1000 with the rounded hood with a honda gx390 or a similar clone and know if it fits under the hood? I have seen that many have repowered the 1050 with gx390 but then have to modify the exhaust and intake, is it the same on the 800?
Or should I go with the gx270 (9hp) maby it fits under the hood without modification?
Anyone done anything like this?
#2 Bolens 1000 ONLINE
  • 14,612 Thanks
  • 17,951 posts
Posted May 03, 2017 - 06:20 AM
Id find another Wisconsin to put in there but thats just me........
  • boyscout862, 29 Chev and Bolens800uk have said thanks
#3 Jooohan87 OFFLINE
Jooohan87
  • 11 Thanks
  • 22 posts
Posted May 03, 2017 - 07:15 AM
Yeah me too if I could find one, but here in sweden its easier to find "bigfoot" than wisconsin parts ;)
  • Bruce Dorsi, KennyP, boyscout862 and 1 other said thanks
#4 chieffan OFFLINE
  • 8,799 Thanks
  • 6,034 posts
Posted May 03, 2017 - 07:31 AM
I have a good 8hp Wisconsin but would be mighty costly by the time you had your hands on it.
#5 glgrumpy OFFLINE
  • 8,354 Thanks
  • 7,733 posts
Think they had Briggs 9hp in the G9 a similar tractor. I'm going to try to make one that way that at one time had Tecumseh in it.  That's not a NEW motor for sure, but is what I have here to work with.
#6 Bruce Dorsi OFFLINE
Bruce Dorsi
    Old, but not dead -- yet!
  • 3,861 Thanks
  • 2,428 posts
Posted May 03, 2017 - 08:53 AM
... but here in Sweden
:welcome:  to GTT.
It's nice to see many members from outside the USA & Canada.  ...This just proves the power of the 'net.
Sorry, but I can not answer your original question.
  • 29 Chev said thank you
#7 pharmer ONLINE
pharmer
  • 848 Thanks
  • 762 posts
Posted May 03, 2017 - 09:59 AM
You should let that TV show Finding Bigfoot you know where he is.
#8 Jooohan87 OFFLINE
Jooohan87
  • 11 Thanks
  • 22 posts
Posted May 03, 2017 - 02:52 PM
Maby I can give the wisconsin s8d 1 more chance. Anyone got the manual for the carburetor and the engine? Cant find anything, thanks
#9 KennyP ONLINE
  • 35,069 Thanks
  • 44,091 posts
Posted May 03, 2017 - 03:04 PM
:wave: Welcome to the forum! Here's a parts manual! This may be the Operators manual.
  • Bolens 1000 said thank you
#10 Jooohan87 OFFLINE
Jooohan87
  • 11 Thanks
  • 22 posts
Posted May 03, 2017 - 03:52 PM
If found that there is a hole under the bowl, looks like its treads in there, guessing im missing something here, like a drain plug? Not familiar to this carburetors.
Also missing the fuelcap..
#11 KennyP ONLINE
  • 35,069 Thanks
  • 44,091 posts
Posted May 03, 2017 - 04:33 PM
Bolens 1000 sells parts, maybe he has something.
#12 Bolens 1000 ONLINE
  • 14,612 Thanks
  • 17,951 posts
Posted May 03, 2017 - 05:06 PM
Kenny linked you the proper files above.
There is a drain plug on the bottom of some models, all models have a brass vent near where the air cleaner elbow mounts.
If you see a hole on the bottom with threads your missing your plug and thats your issue right there no gas will stay in the carb.
I can supply any parts needed
#13 CanadianHobbyFarmer OFFLINE
CanadianHobbyFarmer
  • 1,173 Thanks
  • 694 posts
Posted May 03, 2017 - 05:08 PM
I would stick with the Wisconsin if you can get it running. I have a 1054 here that the previous owner swapped a Honda GX240 into. He originally had the Honda in a Bolens  600 and had to cut the hood to clear both the intake and exhaust (the 600 hood is similar in shape, height and width to the 800, 900 and 1000 if I am not mistaken, but not as long). Fortunately for me, he decided to swap the 600 hood onto the 1054, rather than cut the 1054 hood as well. I got the original hood, Wisconsin engine and the rest of the 600 in the deal, so I can maybe one day put the 1054 back to somewhere near what it should look like. More to the point The 600 originally had a Briggs and Stratton engine in it that did clear the hood. If you do have to repower, you should be able to find a Briggs that will clear the hood ( assuming they are easy to find over there).
BTW welcome to the site!
Jim
Edited by CanadianHobbyFarmer, May 03, 2017 - 05:09 PM.
#14 Jooohan87 OFFLINE
Jooohan87
  • 11 Thanks
  • 22 posts
Posted May 04, 2017 - 06:35 AM
I found on another forum about the hole under the carb, post #52
http://www.mytractor...s/352218?page=6
Can anyone confirm the "vent hole"
Thanks
#15 Bolens 1000 ONLINE
  • 14,612 Thanks
  • 17,951 posts
Posted May 04, 2017 - 08:20 AM
Yes thats the vent, there is supposed to be brass filter material in there
  • Jooohan87 said thank you
