Making A New Seat Pan For A Bolens 1050 Project
22 replies to this topic
#1 29 Chev ONLINE
29 Chev
    A Little Off Plumb
  • 22772 Thanks
  • 7527 posts
Posted May 02, 2017 - 05:29 PM
With the last few days being wet and cool I was motivated to work indoors instead of cleaning up the lawn so I decided I would try and fabricate a new seat pan for a 1050 as one of mine is not in the best of shape.  While the 1050 seat pan may be plentiful in some areas here in Southwestern Ontario they are not overly plentiful and are usually pitted, rusty and have some cracking at the rear bend and welds.  With the exchange rate on the Canadian Dollar not in my favour and since I had some 16 gauge sheet metal from another seat project I decided it would be less expensive to try and make one so I made up some paper patterns using the 1050 seat that I have to test fit covers and padding with - it is badly pitted and has been welded at the rear bend but works fine for fitting the covers.  I knew I would not be able to do the bend at the back as well as the side bends so I decided to make the seat in two pieces and weld them together where the back bend would be.  Used the patterns to cut out new steel and then drilled the holes in the bottom piece and the bolt reinforcing plate.  Once that was done I marked out where the creases and bends in the lower part should be and bent it in the sheet metal brake.  It turned out looking not to bad in my opinion so I marked and bent the back piece.  I made a template out of cardboard to get the correct angle on the bends using the old seat and then I marked the template against the brake blade and cut it so I could check the angle while I was bending the steel as you can see in the pictures.
  • Bolens 1000, LPBolens, Bruce Dorsi and 14 others have said thanks
#2 WrenchinOnIt OFFLINE
WrenchinOnIt
    Got Sum
  • 5112 Thanks
  • 1215 posts
Posted May 02, 2017 - 05:31 PM
After that last fabrication project,you'll do this one handed :)
  • blackjackjakexxix, SamMC, stiemmy and 4 others have said thanks
#3 29 Chev ONLINE
29 Chev
    A Little Off Plumb
  • 22772 Thanks
  • 7527 posts
Got the back piece bent and then set the pieces on the old seat pan to see how close they looked.  If it stays raining tomorrow I may try and weld the two pieces together - time will tell.
  • Bolens 1000, Bruce Dorsi, blackjackjakexxix and 9 others have said thanks
#4 29 Chev ONLINE
29 Chev
    A Little Off Plumb
  • 22772 Thanks
  • 7527 posts
Posted May 02, 2017 - 05:33 PM
Thanks - it is definitely not as complicated - will see how it turns out.
  • stiemmy, logmillingman and Reed Breneman have said thanks
#5 Bolens 1000 ONLINE
  • 17554 Thanks
  • 18863 posts
Posted May 02, 2017 - 05:58 PM
Very Nice!
Glad we have options too keep our tractors as original as possible!
  • blackjackjakexxix, WrenchinOnIt, boyscout862 and 5 others have said thanks
#6 tater195 OFFLINE
tater195
  • 2347 Thanks
  • 1492 posts
Posted May 02, 2017 - 06:05 PM
I have done the tricky bends like the back of your seat by making an angle iron jig to use in the vice or bolt to a work bench. You may have to drill a few holes in the pan to get it to clamp tight, but those can be welded easier than a 2 foot seam
Edited by tater195, May 02, 2017 - 06:06 PM.
  • stiemmy, 29 Chev, Bolens800uk and 2 others have said thanks
#7 LilysDad OFFLINE
LilysDad
    Anything Red . . .
  • 19098 Thanks
  • 11900 posts
Posted May 02, 2017 - 06:37 PM
I'm impressed with your work!
  • 29 Chev, logmillingman and Reed Breneman have said thanks
#8 stiemmy OFFLINE
stiemmy
  • 2541 Thanks
  • 1830 posts
Posted May 02, 2017 - 06:53 PM
Very well said!
Edited by stiemmy, May 02, 2017 - 06:53 PM.
  • blackjackjakexxix, WrenchinOnIt, logmillingman and 1 other said thanks
#9 Bolens800uk OFFLINE
Bolens800uk
  • 2663 Thanks
  • 1480 posts
Posted May 02, 2017 - 07:59 PM
Another skilful project is underway. I wonder if you could turn your hand to fabricate belt guards for the Ride a Matics?!......:-)
#10 boyscout862 OFFLINE
  • 15263 Thanks
  • 10024 posts
Posted May 02, 2017 - 08:50 PM
There seems to be alot of old GTs that have those seat frames. The seat on my Wheelhorse C160 is almost the same but it has a slot in the back to allow agjustment of the rear cushion. A press brake could do that bend for you. Good Luck, Rick
Edited by boyscout862, May 02, 2017 - 08:50 PM.
#11 29 Chev ONLINE
29 Chev
    A Little Off Plumb
  • 22772 Thanks
  • 7527 posts
Posted May 03, 2017 - 08:45 AM
Would have to have one in front of me to work with or good accurate drawings of one but could see what I could do if someone has one.
  • blackjackjakexxix, boyscout862, Bolens800uk and 1 other said thanks
#12 Husky OFFLINE
Husky
  • 1509 Thanks
  • 1202 posts
Posted May 03, 2017 - 11:14 AM
That is fantastic fabrication nice work so far.
  • boyscout862, 29 Chev, Bolens800uk and 1 other said thanks
#13 Bolens800uk OFFLINE
Bolens800uk
  • 2663 Thanks
  • 1480 posts
Posted May 03, 2017 - 11:32 AM
Hopefully someone in your area may e able to assist. Excellent workmanship yet again.
  • 29 Chev and logmillingman have said thanks
#14 DH1 OFFLINE
DH1
    Electric Tractors
  • 5497 Thanks
  • 5633 posts
Posted May 03, 2017 - 12:30 PM
Wow how do you cut your metal so straight?
  • 29 Chev said thank you
#15 29 Chev ONLINE
29 Chev
    A Little Off Plumb
  • 22772 Thanks
  • 7527 posts
Posted May 03, 2017 - 03:06 PM
Just draw a line with a pen and then use a Dewalt sawsall with a 24 tooth short metal cutting blade - take my time and clamp the metal to a 2 x 4 so it doesn't bounce and keep the blade at about a 45 degree angle to the steel.  If it is dark I sometimes will put a magnetic trouble light on the steel to help me see the line.  I cut the straight lines and then on the rounded corners I draw a straight line across the corner and cut what I can and then use the 4-1/2" angle grinder with a flap wheel on it to sand off the bit of metal that is left.
  • DH1, blackjackjakexxix, WrenchinOnIt and 2 others have said thanks
