Sold
Cub Cadet 70
6 replies to this topic
#1 EricFromPa OFFLINE
EricFromPa
  • 4,303 Thanks
  • 3,415 posts
Posted May 01, 2017 - 02:12 PM
I really don't want to but I NEED a good dependable riding mower so
Up for Trade is my Late uncles 1963 Cub Cadet 70 with Cub Cadet dealer optioned Kohler K181 8hp engine Perfect 36" cast end deck and Tire chains and Plow.
This one doesn't have any dealer options but the upgraded engine.
Fenders are home made by my uncle but very very well done.
Engine needs rings and a light honing.She Smokes but the bore is good and straight and the piston and connecting rod are reusable. Pretty Hard to find (don't like the work Rare lol) engine to with 2.875" bore 2.750" stroke and slightly higher compression K141-K160 small bore head.
New Points and plunger
New Coil
New air filter
New Starter Generator
New Voltage regulator
Fresh carb kit with new float,needle and seat
New Sediment bowl
New axle seals and rear pan seal with Fresh Hytran
Fresh deck belts
Middle Spindle turned down and fresh bearings Other 2 are good and quiet
New front tires with tubes
Rear tires are cracked a bit but have tubes and hold air
Battery is a fresh 380cca 450ca Decka would like to keep it for the new mower but it can go with it.
She runs and mows but smokes pretty bad. Could have it bored to K181 STD bore and order a $70 ebay kit and it would be like a new engine.
Plow has not been restored has some rust on it and it's missing the lift rod but it's solid with very little wear on the skids.Would like to keep the plow and use it on my 582 but I'll have to add metal to the plow under carriage.
Will Trade even up for a good dependable clean Lawn tractor or Garden tractor with 46" or larger deck. Would like something 10 years old or newer but will consider a older GT as long as she's in perfect running and working condition.
Located in New Paris,Bedford county Pennsylvania
I Will Not sell it.I need a good dependable mower. My $100 craigslist find Gardenway Troy Bilt blew a rod and the hydro tranny is weak so it's not worth fixing. Heck $100 and it lasted me 6 years but left me sitting with 1/2 the yard mowed lol
I have another Small bore K181 block that comes with it .010 over 2.885" with .010 under crank but needs piston rod and rings.This fella out of Greece has small bore rings in STD .010 and .020 over
http://www.ebay.com/...goAAOSwl9BWGQ6l
Edited by EricFromPa, May 01, 2017 - 05:59 PM.
  • Traill95 said thank you
#2 637Yeoman ONLINE
637Yeoman
  • 1,691 Thanks
  • 1,362 posts
Posted May 01, 2017 - 02:25 PM
Man i would love that, i would want to build it into a puller, but the smart side of me wouldnt want to ruin it, considering what it is.
Im sure it will be gone soon!
#3 EricFromPa OFFLINE
EricFromPa
  • 4,303 Thanks
  • 3,415 posts
Posted May 01, 2017 - 06:03 PM
Holding off posting this on Craigslist for a while. Figured someone here would appreciate and take good care of it.
I'm back to push mowing till I find a good mower.
  • jbailey and 637Yeoman have said thanks
#4 Macmagee OFFLINE
Macmagee
  • 30 Thanks
  • 67 posts
Posted May 05, 2017 - 05:45 PM
I have a Murray 12hp ic in good shape would you like to trade?
#5 637Yeoman ONLINE
637Yeoman
  • 1,691 Thanks
  • 1,362 posts
Posted May 06, 2017 - 01:32 PM
Does it have a deck? I know im not the one selling or trading, but pictures would help too!
#6 EricFromPa OFFLINE
EricFromPa
  • 4,303 Thanks
  • 3,415 posts
Posted May 06, 2017 - 05:16 PM
Small Update
I found rings for it.Just ordered a set and another gasket kit for it.Depending on how it runs out after honing and installing rings I may keep it.
Going to be atleast a week before I have time to pull the engine again and hone it. So If it's not gone by then I'll more than likely keep it and just mow with it untill I can find another cheap rider to mow with.
Serial numbers are 68945 so it was built in Late October of 1963. Which is pretty cool because they only made 2901 CC70s in 1963.
Edited by EricFromPa, May 06, 2017 - 07:23 PM.
#7 EricFromPa OFFLINE
EricFromPa
  • 4,303 Thanks
  • 3,415 posts
Posted May 08, 2017 - 07:35 PM
SOLD SOLD SOLD
Traded for a 1998 Toro Wheel Horse 312-8 with 270 hours on the clock.It has a wiring issue that I have to track down but I think I did pretty good.She runs smooth and cuts grass.Should last for a good while.And Both of us are happy which was my main concern.
Hey I got my 1st running Red tractor woohoo lol
Edited by EricFromPa, May 08, 2017 - 07:40 PM.
  • KennyP and 637Yeoman have said thanks
Also tagged with one or more of these keywords: Sold
