Vanguard V-Twin 20 HP 351447-1075A1 Revival
118 replies to this topic
#106 Trav1s OFFLINE
Trav1s
    Got points?
  • 2,925 Thanks
  • 4,085 posts
Posted August 10, 2017 - 09:16 AM
Early
#107 Trav1s OFFLINE
Trav1s
    Got points?
  • 2,925 Thanks
  • 4,085 posts
Posted August 10, 2017 - 02:44 PM
Wow is the adapter sweet. I will get pics tomorrow
#108 SupplySergeant ONLINE
SupplySergeant
    Eggman's Dad
  • 1,557 Thanks
  • 889 posts
Posted August 10, 2017 - 10:00 PM
That was fast! Occasionally just gotta love the US Postal Service!
  • Trav1s said thank you
#109 Trav1s OFFLINE
Trav1s
    Got points?
  • 2,925 Thanks
  • 4,085 posts
Posted August 11, 2017 - 06:47 AM
Between you being close to Louisville and me in CR it made for a fast ride.
  • SupplySergeant said thank you
#110 Trav1s OFFLINE
Trav1s
    Got points?
  • 2,925 Thanks
  • 4,085 posts
Posted August 11, 2017 - 03:40 PM
Should I put never seize on the crank before installing the adapter?
#111 Trav1s OFFLINE
Trav1s
    Got points?
  • 2,925 Thanks
  • 4,085 posts
Posted August 11, 2017 - 04:43 PM
Here it is in all of it's glory!
  • KennyP, SupplySergeant and Mark 149 J. have said thanks
#112 dodge trucker ONLINE
dodge trucker
  • 1,885 Thanks
  • 2,506 posts
Posted August 12, 2017 - 07:39 AM
That never hurts. Unless you know that you will never ever take it apart again for any reason.
#113 SupplySergeant ONLINE
SupplySergeant
    Eggman's Dad
  • 1,557 Thanks
  • 889 posts
Posted August 12, 2017 - 07:42 PM
I put that stuff on everything with a metal-to-metal fit, unless it needs loctite.
#114 SupplySergeant ONLINE
SupplySergeant
    Eggman's Dad
  • 1,557 Thanks
  • 889 posts
Posted August 12, 2017 - 07:45 PM
Looks like it fits, I can uncross my fingers!
#115 dropped82 ONLINE
dropped82
    Nut Case
  • 2,078 Thanks
  • 1,599 posts
Posted August 12, 2017 - 08:52 PM
That adapter is beautiful. If you don't mind me asking, what's that key made of? Is it a softer metal than the crank? Only reason I ask is because I've repaired ones that were not. If the situation arises you want to make sure the key is the weak point.
Edited by dropped82, August 12, 2017 - 08:55 PM.
  • Alc and SupplySergeant have said thanks
#116 SupplySergeant ONLINE
SupplySergeant
    Eggman's Dad
  • 1,557 Thanks
  • 889 posts
Posted August 12, 2017 - 09:38 PM
The key is actual keystock, so it should be plain old 1018 steel, much softer than the crank. Good point, for anyone else needing to make one!
  • KennyP and dropped82 have said thanks
#117 Trav1s OFFLINE
Trav1s
    Got points?
  • 2,925 Thanks
  • 4,085 posts
Posted August 13, 2017 - 07:33 AM
The next thing is to figure the spacing so that the PTO clutch sits in the correct place.  Time to do some digging/reading.
#118 SupplySergeant ONLINE
SupplySergeant
    Eggman's Dad
  • 1,557 Thanks
  • 889 posts
Posted August 13, 2017 - 08:25 AM
Are you going to need a spacer collar to keep the clutch from going too far down the shaft? I still have enough of the shaft adapter material to make one, its 2" diameter, so I can make a custom-length shaft collar easily enough.
#119 Trav1s OFFLINE
Trav1s
    Got points?
  • 2,925 Thanks
  • 4,085 posts
Posted August 13, 2017 - 02:29 PM
Looking into that this afternoon unless I fall into the potential Sunday afternoon nap.
