Vanguard V-Twin 20 HP 351447-1075A1 Revival
118 replies to this topic
#91 SupplySergeant ONLINE
SupplySergeant
    Eggman's Dad
  • 1,557 Thanks
  • 889 posts
Posted August 04, 2017 - 07:36 AM
At the open end of the 3" crank the keyway is .2360" when measured at the bottom of the keyway.
The PTO clutch keyway is .3765 measured the same way.
Clutch bore and bracket depth is 2.5" but the adapters I have found all go for 3" due to aligning the clutch on the crank and keeping it lined up with the mule drive.
Odd measurement on the crank, it's actually equal to 6mm. No problem, I'll just make a key that fits into the clutch, and is tall enough to fit through the shaft adapter, and cut the other side to 6mm wide. I might be able to get this made today!
#92 SupplySergeant ONLINE
SupplySergeant
    Eggman's Dad
  • 1,557 Thanks
  • 889 posts
Posted August 04, 2017 - 07:56 AM
Got it drawn up, I should be able to work on it today.
#93 SupplySergeant ONLINE
SupplySergeant
    Eggman's Dad
  • 1,557 Thanks
  • 889 posts
Posted August 04, 2017 - 02:21 PM
IMG 20170804 152232
IMG 20170804 151625 (2)
IMG 20170804 151615
Not done yet, I had an emergency job to do this afternoon. But the actual adapter only needs a couple of setscrews added. I'll do that and make the special key Monday morning. That chunk of material in the key slot of the adapter is the raw stock for the key.
Edited by SupplySergeant, August 04, 2017 - 02:24 PM.
  • Trav1s and Mark 149 J. have said thanks
#94 Trav1s ONLINE
Trav1s
    Got points?
  • 2,925 Thanks
  • 4,087 posts
Posted August 05, 2017 - 06:49 AM
Wow!  That is too cool to be able to make something out of thin air.  I so want to learn that skill and to be able to think like that!
I pulled the valve covers off yesterday and plan to adjust the valves today.  This is an turing out to be a project that challenges my brain and that is a good thing.
  • SupplySergeant said thank you
#95 SupplySergeant ONLINE
SupplySergeant
    Eggman's Dad
  • 1,557 Thanks
  • 889 posts
Posted August 05, 2017 - 08:29 AM
It helps to have a big scrap pile! I made it out of a piece of stainless steel leftover from making a bunch of little pressure vessels, it should last forever.
Is the clutch held on by a bolt into the end of the crankshaft? If it is, I don't need to put in the setscrews.
#96 Trav1s ONLINE
Trav1s
    Got points?
  • 2,925 Thanks
  • 4,087 posts
Posted August 05, 2017 - 10:22 AM
Yes it is but does it matter that the crank is 3" long?
#97 SupplySergeant ONLINE
SupplySergeant
    Eggman's Dad
  • 1,557 Thanks
  • 889 posts
Posted August 05, 2017 - 11:44 AM
I'm not sure, but I did make the adapter 3" long. I'll go ahead and put the setscrews in, to hold it on the crank.
  • Trav1s said thank you
#98 Trav1s ONLINE
Trav1s
    Got points?
  • 2,925 Thanks
  • 4,087 posts
Posted August 05, 2017 - 12:29 PM
Wow!!!
#99 Trav1s ONLINE
Trav1s
    Got points?
  • 2,925 Thanks
  • 4,087 posts
Posted August 05, 2017 - 04:55 PM
Perhaps this thread should be moved to the Repower section in light of the current subject matter.  Mods, if this feels appropriate feel free to move this to that section.
#100 SupplySergeant ONLINE
SupplySergeant
    Eggman's Dad
  • 1,557 Thanks
  • 889 posts
Posted August 07, 2017 - 01:38 PM
IMG 20170807 142955
IMG 20170807 142856
Ready to go! Just PM me the address, I'll get it in the mail.
I put a small setscrew in the adapter, it'll hold the thing in place while you slide the clutch on.
Edited by SupplySergeant, August 07, 2017 - 01:40 PM.
#101 Trav1s ONLINE
Trav1s
    Got points?
  • 2,925 Thanks
  • 4,087 posts
Posted August 07, 2017 - 02:18 PM
Sarg that is beautiful!!!!!!!
#102 SupplySergeant ONLINE
SupplySergeant
    Eggman's Dad
  • 1,557 Thanks
  • 889 posts
Posted August 07, 2017 - 02:53 PM
Forgot to mention, I made the key 4" long, you can hacksaw it to the best length, and keep the rest as a spare.
  • KennyP and Trav1s have said thanks
#103 Trav1s ONLINE
Trav1s
    Got points?
  • 2,925 Thanks
  • 4,087 posts
Posted August 09, 2017 - 08:15 AM
:worshippy1:  :worshippy1:  :worshippy1:  :worshippy1:  :worshippy1:  :worshippy1:  Sarg!!
  • KennyP and SupplySergeant have said thanks
#104 KennyP OFFLINE
  • 34,266 Thanks
  • 43,390 posts
Posted August 09, 2017 - 08:35 AM
He does a fine job on things!
  • Trav1s and SupplySergeant have said thanks
#105 SupplySergeant ONLINE
SupplySergeant
    Eggman's Dad
  • 1,557 Thanks
  • 889 posts
Posted August 09, 2017 - 09:16 AM
It's a great way for me to take part in the hobby between plow days!
