Vanguard V-Twin 20 HP 351447-1075A1 Revival
118 replies to this topic
#61 Trav1s ONLINE
Trav1s
    Got points?
  • 2,988 Thanks
  • 4,157 posts
Posted July 08, 2017 - 04:34 PM
I have not done anything else other than crank down the gear puller only to have no progress on the pulley.  Any suggestions? Sawzall or dremel and cut the stupid thing in half?!?
#62 gopher OFFLINE
gopher
  • 742 Thanks
  • 746 posts
Posted July 08, 2017 - 05:38 PM
I've had luck with mapp torch with wide pulley. Have pressure on puller and just heat in the valley of pulley along the key-way only. Doesn't hurt to have some ice cubes to keep shaft cool.
#63 SupplySergeant OFFLINE
SupplySergeant
    Eggman's Dad
  • 1,616 Thanks
  • 917 posts
Posted July 08, 2017 - 06:16 PM
I'll second this. Even better if you can use a rosebud tip on an oxy-acetylene torch.
#64 Trav1s ONLINE
Trav1s
    Got points?
  • 2,988 Thanks
  • 4,157 posts
Posted July 10, 2017 - 08:59 AM
My repower helper has a torch and I need to get out and visit with him.  I know he is excited to get working on this.
  • SupplySergeant said thank you
#65 Trav1s ONLINE
Trav1s
    Got points?
  • 2,988 Thanks
  • 4,157 posts
Posted July 12, 2017 - 09:33 PM
I took things into my own hands. Dremel and cutoff wheel as well as grinder.
  • SupplySergeant and Mark 149 J. have said thanks
#66 SupplySergeant OFFLINE
SupplySergeant
    Eggman's Dad
  • 1,616 Thanks
  • 917 posts
Posted July 12, 2017 - 09:58 PM
Hmmmmm...... looks like my work!
  • WNYTractorTinkerer and Mark 149 J. have said thanks
#67 Trav1s ONLINE
Trav1s
    Got points?
  • 2,988 Thanks
  • 4,157 posts
Posted July 13, 2017 - 06:43 AM
Is that a good thing or a bad thing?
#68 SupplySergeant OFFLINE
SupplySergeant
    Eggman's Dad
  • 1,616 Thanks
  • 917 posts
Posted July 13, 2017 - 09:20 AM
As long as the job is done, and no one is hurt, I'd call it good!
  • Trav1s said thank you
#69 Trav1s ONLINE
Trav1s
    Got points?
  • 2,988 Thanks
  • 4,157 posts
Posted July 13, 2017 - 10:16 AM
I really hope to get this off today so I can try the K series PTO clutch as an option to getting an adapter for the Onan clutch.
#70 Trav1s ONLINE
Trav1s
    Got points?
  • 2,988 Thanks
  • 4,157 posts
Posted July 14, 2017 - 08:41 AM
I WIN!!!!
  • Mark 149 J. said thank you
#71 Trav1s ONLINE
Trav1s
    Got points?
  • 2,988 Thanks
  • 4,157 posts
Posted July 14, 2017 - 08:58 AM
I WIN!!!!
Boom!
  • KennyP, SupplySergeant and Mark 149 J. have said thanks
#72 Trav1s ONLINE
Trav1s
    Got points?
  • 2,988 Thanks
  • 4,157 posts
Posted July 14, 2017 - 10:44 AM
So I have compared the K series and the Onan PTO clutches to the Vanguard block. There are holes for each design so either will bolt to the block. The challenge will be spacing to get the pulley location on the crank in the proper location. Here are my thoughts so far...
K series PTO clutch is a direct fit to the crank but the wiring is different and would need to be adapted to the wiring of the 318.
Onan clutch needs adapter to fit 1" crank but is a direct fit to the wiring harness.
I think I will stick with the Onan clutch and work on finding a crank adapter - 1" to 1 7/16"
#73 Trav1s ONLINE
Trav1s
    Got points?
  • 2,988 Thanks
  • 4,157 posts
Posted July 15, 2017 - 08:09 AM
leaving this here for now
http://www.ebay.com/...18/332293753641
  • KennyP, WNYTractorTinkerer and SupplySergeant have said thanks
#74 dodge trucker ONLINE
dodge trucker
  • 1,959 Thanks
  • 2,595 posts
Posted July 15, 2017 - 10:00 AM
I had  a chanceto pick up an Onan twin a year ago for free, I snoozed and lost out but I'd have had to go the "other' way on a PTO adaptation  either find a clutch to fit a 1-7/16 shaft or yank the crank and have the PTO end machined down skinnier....
#75 Trav1s ONLINE
Trav1s
    Got points?
  • 2,988 Thanks
  • 4,157 posts
Posted July 15, 2017 - 11:49 AM
Part of the reason I am going with the Onan clutch is that it looks to be in better shape than either of the K series clutches that I have.  I really don't want to replace a clutch in the near future after all of this work.  I thought about mix-n-match with parts from both Onan and K series clutches but that leaves me with useless parts.
