Vanguard V-Twin 20 HP 351447-1075A1 Revival
118 replies to this topic
#31 Trav1s ONLINE
Trav1s
    Got points?
  • 2,988 Thanks
  • 4,156 posts
Posted May 04, 2017 - 12:24 PM
I need to figure out how much it is.  The T.H.E Company website does not list this item as available to order online so I will have to call them and speak to the parts department.  Maybe I can do that tomorrow.
https://the-co.com
Edited by Trav1s, May 04, 2017 - 10:03 PM.
  • SupplySergeant said thank you
#32 Trav1s ONLINE
Trav1s
    Got points?
  • 2,988 Thanks
  • 4,156 posts
Posted May 05, 2017 - 09:44 AM
Funny how this has drifted into the repower realm of the project so quickly.  Maybe mods should move it into that subsection the forum...   :watch_over_fence:
  • KennyP and SupplySergeant have said thanks
#33 Trav1s ONLINE
Trav1s
    Got points?
  • 2,988 Thanks
  • 4,156 posts
Posted May 05, 2017 - 01:37 PM
Grabbed the Simple Green and toothbrush and went to work on the Vanguard after having it run again.  I suspect the diaphragm fuel pump is bad from sitting.  At this point my parts list is as follows:
- air filter (pre filter kept the filter pretty clean)
- oil filter (Baldwin B7165 on it now)
- breather (better condition that I expected)
- plugs (Has AC FR3LS in it)
The pulley on the crank looks to be a real pain.  The set screws are not cooperating so I started drilling them out after stripping them.
Edited by Trav1s, May 06, 2017 - 07:10 AM.
#34 Trav1s ONLINE
Trav1s
    Got points?
  • 2,988 Thanks
  • 4,156 posts
Posted May 05, 2017 - 03:07 PM
Pics of today's work with the simple green and brushes.
  • KennyP, Sawdust and Mark 149 J. have said thanks
#35 Trav1s ONLINE
Trav1s
    Got points?
  • 2,988 Thanks
  • 4,156 posts
Posted May 05, 2017 - 03:08 PM
Blower cover redo
  • KennyP, Sawdust, SupplySergeant and 1 other said thanks
#36 SupplySergeant OFFLINE
SupplySergeant
    Eggman's Dad
  • 1,614 Thanks
  • 916 posts
Posted May 05, 2017 - 05:50 PM
Looking good!
#37 Trav1s ONLINE
Trav1s
    Got points?
  • 2,988 Thanks
  • 4,156 posts
Posted May 05, 2017 - 07:33 PM
More pics. Removed the muffler and painted the air cleaner assembly blitz black to match the blower shroud.
Edited by Trav1s, May 05, 2017 - 08:51 PM.
  • KennyP, SupplySergeant and Mark 149 J. have said thanks
#38 Trav1s ONLINE
Trav1s
    Got points?
  • 2,988 Thanks
  • 4,156 posts
Posted May 06, 2017 - 07:13 AM
I am also going to replace the hose than runs from the crank breather to the base of the air cleaner assembly as well as the rubber assembly that connects the flywheel blower housing to the base of the air cleaner assembly.  The rubber is hard and they are easy to replace while the engine is apart for cleanup and paint.
Edited by Trav1s, May 06, 2017 - 08:25 AM.
  • WNYTractorTinkerer and SupplySergeant have said thanks
#39 Trav1s ONLINE
Trav1s
    Got points?
  • 2,988 Thanks
  • 4,156 posts
Posted May 06, 2017 - 04:02 PM
Parts list for the Vanguard
Manual Item #
163A - gasket (x2) air cleaner gasket - 692087
1004A -  air duct - 691540
121D - carb kit - 842873
1047 -  adapter kit - 841580
11B - hose - 691535 breather tube
8 + 9 - breather and gasket - 808894 breather, 809094 gasket
445 - air cleaner - 394018s
1027 - oil filter - 49932s = 4", 808033 - small 8008235 adapter
337 - plug - 792015 for 1075 type
Edited by Trav1s, May 06, 2017 - 04:03 PM.
  • KennyP and Sawdust have said thanks
#40 Trav1s ONLINE
Trav1s
    Got points?
  • 2,988 Thanks
  • 4,156 posts
Posted May 06, 2017 - 04:37 PM
Tins in place til parts arrive.
#41 Trav1s ONLINE
Trav1s
    Got points?
  • 2,988 Thanks
  • 4,156 posts
Posted May 10, 2017 - 08:47 AM
Just sent my parts "wish list" to Bolens 1000 to keep the project moving.  I am targeting a mid-June implementation date at this time.
#42 Trav1s ONLINE
Trav1s
    Got points?
  • 2,988 Thanks
  • 4,156 posts
Posted May 10, 2017 - 03:41 PM
Got those parts ordered this afternoon.  Progress makes me  :D
#43 Trav1s ONLINE
Trav1s
    Got points?
  • 2,988 Thanks
  • 4,156 posts
Posted May 13, 2017 - 07:13 AM
Waiting... :watch_over_fence:
#44 KennyP ONLINE
  • 35,107 Thanks
  • 44,128 posts
Posted May 13, 2017 - 07:36 AM
That's always fun!
#45 Trav1s ONLINE
Trav1s
    Got points?
  • 2,988 Thanks
  • 4,156 posts
Posted May 16, 2017 - 09:33 PM
Picked up a firewall insulation kit and a firewall adapter kit to convert the hole in the firewall to fit the vanguard.
