Vanguard V-Twin 20 HP 351447-1075A1 Revival
118 replies to this topic
#16 KennyP OFFLINE
  • 35,089 Thanks
  • 44,105 posts
Posted May 01, 2017 - 05:00 PM
I mentioned that I was looking for engine for a 318 I picked up to a few people around the church and this is the result.  At both churches people are really surprised to hear about my projects and mechanical abilities.  If this this ends up working out I am going to try to give some compensation to my supplier but anticipate he will refuse.
Make a donation to the church in his name!
  • Trav1s said thank you
#17 Trav1s ONLINE
Trav1s
    Got points?
  • 2,987 Thanks
  • 4,155 posts
Posted May 01, 2017 - 09:29 PM
Oil filter on it is B7165 (Baldwin)
Briggs part number 492932S
This is xref list I found:
Replacement oil filters for BRIGGS-STRATTON 492932:
Brand  Model
Baldwin  B7165
Beck/Arnley  041-0767
Beck/Arnley  041-8078
BIG A  92065
Bosch  0986452058
BRIGGS & STRATTON  120485
BRIGGS & STRATTON  492056
BRIGGS & STRATTON  492932
BRIGGS & STRATTON  492932S
BRIGGS & STRATTON  5049
BRIGGS & STRATTON  695396
BRIGGS & STRATTON  696854
BRIGGS & STRATTON  842921
CARQUEST  85065
Champ  LF503
CROSLAND  2099
CUB CADET  120-5008
Donaldson  P502024
Fleetguard  LF16108
Fram  PH8170
HASTINGS  LF503
HATZ  50302800
John Deere  AM125424
John Deere  AM125424C
John Deere  AM131948
John Deere  GY20577
KAWASAKI  49065-7007
LISTER-PETTER  751-12870
LUBER-FINER  PH3656
Mann Filter  W77
NAPA  1056
NAPA  1056MP
NAPA  7035
Tecumseh  36563
Tecumseh  36961
Tecumseh  740057
Wix  51056
Wix  57035
Edited by Trav1s, May 01, 2017 - 09:31 PM.
  • KennyP and Sawdust have said thanks
#18 Trav1s ONLINE
Trav1s
    Got points?
  • 2,987 Thanks
  • 4,155 posts
Posted May 03, 2017 - 02:51 PM
Just confirmed my suspicions - digital caliper confirms that it is a 1" crank.  I hope to see if it will fire later today.
  • KennyP and SupplySergeant have said thanks
#19 Trav1s ONLINE
Trav1s
    Got points?
  • 2,987 Thanks
  • 4,155 posts
Posted May 03, 2017 - 06:38 PM
And it runs! No smoke and no strange sounds during the time it ran on gas dumped into the carb. I will work on cleaning it up tomorrow afternoon.
Edited by Trav1s, May 03, 2017 - 06:40 PM.
  • KennyP, Sawdust, SupplySergeant and 1 other said thanks
#20 SupplySergeant ONLINE
SupplySergeant
    Eggman's Dad
  • 1,614 Thanks
  • 916 posts
Posted May 03, 2017 - 07:16 PM
Forgive my ignorance, but what was the crank size on the original engine?
  • Mark 149 J. said thank you
#21 Trav1s ONLINE
Trav1s
    Got points?
  • 2,987 Thanks
  • 4,155 posts
Posted May 03, 2017 - 08:12 PM
I think the Onan was 1 & 5/8 inch.
Edited by Trav1s, May 03, 2017 - 09:10 PM.
#22 SupplySergeant ONLINE
SupplySergeant
    Eggman's Dad
  • 1,614 Thanks
  • 916 posts
Posted May 03, 2017 - 08:23 PM
I think the Onan was 1 &5/8 inch.
BIG crank! But it shouldn't be too hard to build an adapter to fit the 318's input shaft or clutch.
#23 Trav1s ONLINE
Trav1s
    Got points?
  • 2,987 Thanks
  • 4,155 posts
Posted May 03, 2017 - 09:12 PM
I will measure the clutch off of the Onan tomorrow and post up the info.
I just soaked the set screws on the dual belt pulley with PB blaster and will repeat that tomorrow.
Edited by Trav1s, May 03, 2017 - 09:26 PM.
  • SupplySergeant said thank you
#24 KennyP OFFLINE
  • 35,089 Thanks
  • 44,105 posts
Posted May 04, 2017 - 03:49 AM
Most Onan's are 1-7/16". Hard to find clutches for. I need one for a B48G.
  • Trav1s and SupplySergeant have said thanks
#25 SupplySergeant ONLINE
SupplySergeant
    Eggman's Dad
  • 1,614 Thanks
  • 916 posts
Posted May 04, 2017 - 08:48 AM
I may be able to make a sleeve adapter, to slide on the Vanguard shaft, and fit in the bore of the Onan clutch. Just has to be enough difference to clear the keyways.
If there's enough meat on the hub of a different clutch, I can just bore it and cut a new keyway.
Edited by SupplySergeant, May 04, 2017 - 08:49 AM.
  • Trav1s and Sawdust have said thanks
#26 Trav1s ONLINE
Trav1s
    Got points?
  • 2,987 Thanks
  • 4,155 posts
Posted May 04, 2017 - 11:04 AM
Here are some resources that are worth reviewing.  I hesitate putting them in this thread but it seems to have stirred some good conversation so seems appropriate.  These are write-ups on repowers without kits.
https://plus.google....=CM7dgu73_I6gYA
https://plus.google....=CMiPiu7uzNK5JQ
  • Sawdust said thank you
#27 Trav1s ONLINE
Trav1s
    Got points?
  • 2,987 Thanks
  • 4,155 posts
Posted May 04, 2017 - 11:08 AM
Reading says I will need Briggs 841580 stub shaft... ouch.  These vendors shows it with additional parts for the swap.
http://tewarehouse.com/841580
https://www.jackssma...stratton/841580
Cheapest option here:
https://www.smalleng...shafts3385.html
With shipping to my door it comes out to $142.
Edited by Trav1s, May 04, 2017 - 11:28 AM.
#28 Trav1s ONLINE
Trav1s
    Got points?
  • 2,987 Thanks
  • 4,155 posts
Posted May 04, 2017 - 11:18 AM
 A bit of conversation leads me to believe this engine has 200-300 hours on it. I have a hard time thinking about pulling the heads with them being that low.  If I have to change the gaskets in 200-300 hours that is 10+ years of use for me before I get close to the 700-800 hour window.  Looks like I will install an hour meter and put gaskets on the radar.
#29 Trav1s ONLINE
Trav1s
    Got points?
  • 2,987 Thanks
  • 4,155 posts
Posted May 04, 2017 - 11:21 AM
That is what I need to make the Onan PTO work on the 1" shaft of the Vanguard.
#30 SupplySergeant ONLINE
SupplySergeant
    Eggman's Dad
  • 1,614 Thanks
  • 916 posts
Posted May 04, 2017 - 12:21 PM
About how much are they wanting for that? If it's more than $20-30, I have a nice chunk of 2" stainless shafting should do the trick nicely....
About the stub shaft: how big is the bolt pattern, and what does it have to clear on the backside? I have a 5" diameter x 4" long chunk of cold-rolled, might be able to make that too.
Edited by SupplySergeant, May 04, 2017 - 12:29 PM.
