Tecumseh Solid State Ignition
10 replies to this topic
#1 drbish OFFLINE
drbish
    Collecter
  • 1,557 Thanks
  • 1,361 posts
Posted April 29, 2017 - 02:50 PM
Not sure if that is what they are actually called,I am talking about the ones
that cost a fortune.Is there a way to test them.I have access to several but the engines are locked up.
#2 KennyP OFFLINE
  • 38,408 Thanks
  • 45,945 posts
Posted April 29, 2017 - 03:04 PM
I'd like to know that and the points type as I have 2 tecumseh's here to try to get running. One is points, not sure on the other.
#3 propane1 OFFLINE
propane1
  • 8,725 Thanks
  • 4,131 posts
Posted April 29, 2017 - 03:51 PM
Me too. The engines that are locked up, are they seized or rod gone. I had a spare hh100 engine that would turn about half way, then stop. And would rotate back the other way and stop. So I figued that the ignition part was good, which it was because I used the ignition box on my mf12 about a month ago. But it would be nice to know how to test them.
Noel
#4 jhn9840 ONLINE
jhn9840
  • 373 Thanks
  • 354 posts
Posted April 29, 2017 - 04:12 PM
www.enginesandmagnets.com. I don't claim to know anything about these ignitions. But if you go to that web site it is a real wealth of knowledge about Tecumseh Solid State Ignitions. The owner of the site has studied and conducted many tests of them on his own.
jhn9840
John
  • Bruce Dorsi, KennyP, boyscout862 and 1 other said thanks
#5 KennyP OFFLINE
  • 38,408 Thanks
  • 45,945 posts
Posted April 29, 2017 - 04:34 PM
jhn9840
John
I looked through there and saw nothing on this style of points and magneto.
#6 dodge trucker ONLINE
dodge trucker
  • 2,436 Thanks
  • 3,127 posts
Posted April 29, 2017 - 04:51 PM
there isn't alot to know about that style points and magneto, other than I never knew they used them on the HH (cast iron) series engines at least those  bigger than 7hp.... that style mag was used on most of the aluminum-block Tecumsehs.
Edited by dodge trucker, April 29, 2017 - 04:52 PM.
#7 boyscout862 ONLINE
  • 12,863 Thanks
  • 9,175 posts
Posted April 29, 2017 - 05:00 PM
Those are plain old Tecumseh points that were in many many engines. The solid state ignition is common but now hard to find parts for. Ed Stoller is the man behind Engines and Magnets.   http://home.earthlin...ller/index.html   He provides lots of info including how to diagnose and repair the Tech Solid State Ignition. Good Luck, Rick
#8 Bruce Dorsi OFFLINE
Bruce Dorsi
    Old, but not dead -- yet!
  • 3,915 Thanks
  • 2,451 posts
Posted April 29, 2017 - 05:18 PM
Kenny, that is the same ignition as on your Bolens Lawn Keeper.
points = Tecumseh # 30547
condenser = Tecumseh # 30548
coil = Tecumseh # 30560
Without a specialized coil tester, all you can do is test the ignition primary & secondary for continuity/ohms.
Somewhere on the 'net, I saw a way to build a simple coil tester.
#9 KennyP OFFLINE
  • 38,408 Thanks
  • 45,945 posts
Posted April 29, 2017 - 05:27 PM
That's where I got the pic from. I have an H50 and an LEV120 to get running for a customer. Waiting for the monsoons to ease up!
#10 dodge trucker ONLINE
dodge trucker
  • 2,436 Thanks
  • 3,127 posts
Posted April 29, 2017 - 07:38 PM
the LEV120 is probably electronic, coil outside the flywheel. the H50 is probably as you pictured. Common as dirt.
#11 Tecumseh power OFFLINE
Tecumseh power
  • 1,478 Thanks
  • 1,113 posts
Posted April 29, 2017 - 09:00 PM
You can test the charge coil that sends the power to the solid state with an ohm meter. To check if it is good. That will eliminate 50% of the guess work.
