Brake Band lining
13 replies to this topic
#1 adamjd200 OFFLINE
adamjd200
  • 2,046 Thanks
  • 2,173 posts
Posted April 28, 2017 - 10:46 PM
When I got my Montgomery Ward we figured out pretty quick that the previous owner had removed the brake drum (I have it, it was under the seat), but before I reinstall it I have noticed that the brake band is bare, what material/process would be best to reline it? I need to have working brakes as it will be used on hills regularly.
  • hamman and Traill95 have said thanks
#2 Mtypython ONLINE
Mtypython
  • 346 Thanks
  • 343 posts
Posted April 29, 2017 - 04:06 AM
mcmaster.com  search for brake lining
  • hamman, KennyP, Traill95 and 2 others have said thanks
#3 KennyP ONLINE
  • 38,299 Thanks
  • 45,895 posts
Posted April 29, 2017 - 06:07 AM
Several folks have done this in the last few months. Shouldn't be hard to find a thread on it.
  • hamman and boyscout862 have said thanks
#4 larrybl ONLINE
larrybl
    Texas Member
  • Site Supporter
  • 6,989 Thanks
  • 4,410 posts
Posted April 29, 2017 - 04:00 PM
I used the (6175K811) https://www.mcmaster...lining/=17euoh9
  • KennyP and adamjd200 have said thanks
#5 KennyP ONLINE
  • 38,299 Thanks
  • 45,895 posts
Posted April 29, 2017 - 04:09 PM
And you can use JB Weld to glue it on! Works good. Just need lots of clamps.
  • adamjd200 said thank you
#6 larrybl ONLINE
larrybl
    Texas Member
  • Site Supporter
  • 6,989 Thanks
  • 4,410 posts
Posted April 29, 2017 - 04:48 PM
Procedure can be found here, http://gardentractor...-refresh/page-3
#7 broken arrow OFFLINE
broken arrow
  • 49 Thanks
  • 44 posts
Posted May 07, 2017 - 10:09 AM
Instead of using a lot of clamps, I use the drum itself.
Wrap a piece of wax paper around the drum, coat the lining/band with your preferred adhesive, wrap the assembly around the wax paper/drum, and bolt or clamp the ends together until the adhesive is set.
This would be easier since your drum is off the tractor.
Hope this helps someone,
Dave
#8 adamjd200 OFFLINE
adamjd200
  • 2,046 Thanks
  • 2,173 posts
Posted May 07, 2017 - 08:41 PM
Dave
That is a great idea, I've ordered some lining, should be here tomorrow.
#9 larrybl ONLINE
larrybl
    Texas Member
  • Site Supporter
  • 6,989 Thanks
  • 4,410 posts
Posted May 07, 2017 - 08:49 PM
Should work a treat! I had access to a bunch of clamps for mine. I'll keep this trick in mind.
#10 adamjd200 OFFLINE
adamjd200
  • 2,046 Thanks
  • 2,173 posts
Posted May 07, 2017 - 10:35 PM
Makes sense for me as my brake drum is currently under the seat in the tool box.
#11 KennyP ONLINE
  • 38,299 Thanks
  • 45,895 posts
Posted May 08, 2017 - 05:13 AM
If the drum is easily accessible, why not use it! A pulley could be used in a pinch.
#12 adamjd200 OFFLINE
adamjd200
  • 2,046 Thanks
  • 2,173 posts
Posted May 21, 2017 - 10:26 PM
This is what I have ended up with, not perfect but it will keep me from killing myself on the hills here.0521172300.jpg 0521172300a.jpg
Edited by adamjd200, May 21, 2017 - 10:27 PM.
#13 larrybl ONLINE
larrybl
    Texas Member
  • Site Supporter
  • 6,989 Thanks
  • 4,410 posts
Posted May 21, 2017 - 10:29 PM
Looks good to me!
#14 adamjd200 OFFLINE
adamjd200
  • 2,046 Thanks
  • 2,173 posts
Posted May 21, 2017 - 10:59 PM
Thanks, I use the brake drum but still had to clamp it to get it right.
