John Deere 425 blowing out white smoke and oil from exhaust
8 replies to this topic
#1 Ghoward OFFLINE
Ghoward
  • 1 posts
Posted April 26, 2017 - 09:42 PM
I have a 1995 John Deere 425 garden tractor. It has been sitting for a few years and I started working on it. I replaced the time delay module and rebuilt the carburetor. I got it to run but it rolls out white smoke and oil from the exhaust. I let it run for a while because I thought it would clear but it did not so I shut it down. Anyone have any ideas what could be the cause? Any help would be appreciated. FY I there was so much oil coming out the exhaust everything was covered with oil in my garage.
#2 Xrperry ONLINE
Xrperry
  • 835 Thanks
  • 654 posts
Posted April 27, 2017 - 12:04 AM
Broken oil ring?
#3 Lmiller3358 ONLINE
Lmiller3358
  • 1,466 Thanks
  • 1,412 posts
Posted April 27, 2017 - 03:51 AM
Broken ring, or is there too much oil in it ?
#4 Billy M ONLINE
Billy M
  • 552 Thanks
  • 488 posts
Posted April 27, 2017 - 08:11 AM
Did you check the breather?  The check valve in it may be stuck/gummed up.  See if the carb has any oil in it from the breather.
#5 karel OFFLINE
karel
  • 1,827 Thanks
  • 1,214 posts
Posted April 27, 2017 - 08:27 AM
Slow valve
#6 jms180 ONLINE
jms180
  • 1,220 Thanks
  • 1,404 posts
Posted April 27, 2017 - 10:56 AM
I would do a leak down test and see how that goes
#7 WNYTractorTinkerer ONLINE
WNYTractorTinkerer
    Tinker Master
  • 9,469 Thanks
  • 5,264 posts
Posted April 27, 2017 - 11:11 AM
So many questions left unanswered:
1-  How many hours on it?  How much oil?
1.5-  Compression test-  if it's under 180# its rebuild time..  Leakdown test will evaluate the valves also..
2-  Pull & read the plugs-  How do they look?
3-  pull the radiator cap & start it..  Does it bubble or spit out?  if so the head gaskets need replaced..
4-  Then pull the oil fill cap off-  is there a lot off pressure coming out of the crankcase?  if so-  Rings are shot..
Edited by WNYTractorTinkerer, April 27, 2017 - 11:14 AM.
#8 boyscout862 ONLINE
  • 11,480 Thanks
  • 8,484 posts
Posted April 27, 2017 - 11:32 AM
Welcome to GTT. If you need the engine manual, download it from our Manuals Section. Go to the "Troubleshooting Section" and follow the diagnostic tests. The best way to to figure out what is wrong is to do the troubleshooting from a check list so that you don't miss anything. The start by checking the oil level and smell if there is any gas in it. A leaking fuel pump can dump fuel into the crankcase. The diluted oil can get by the rings. Check the breather for proper operation. Do a compression test assess the rings. Let us know how you make out. Good Luck, Rick
  • Rock farmer said thank you
#9 kencombs OFFLINE
kencombs
  • 21 Thanks
  • 32 posts
Posted April 27, 2017 - 08:47 PM
Lots of good advice there.
I would add this:  White smoke on a gas engine is often due to coolant entering the combustion chamber.  Makes the head gaskets suspect.
