G 14
16 replies to this topic
#1 Grandpa's G14 OFFLINE
Grandpa's G14
  • 9 Thanks
  • 9 posts
Posted April 26, 2017 - 02:37 PM
Hi, brand new today to this group, but I have been trolling here for a bout a year. Against my father's wishes, I held on to my grandfathers g14's and finally rebuilt carb, starter, battery, ignition switch, air filter and housing, and got her running again. I also have two mower decks I am trying to identify with probably 75% of the linkage required. Where can I find the model of mower deck, more importantly will they work. Numbers behind gearbox? Not even sure if it's gear or hydro and I have ordered my parts from sam before. Thanks for the help. I'm tired of hours of dead end research, and felt I should join. Also willing to give up what I don't need(one of the decks). THANKS!
  • Bolens 1000 and 637Yeoman have said thanks
#2 DougT ONLINE
DougT
    Dog Approved
  • 6,681 Thanks
  • 4,845 posts
Posted April 26, 2017 - 03:48 PM
Welcome to the forum. Pictures of what you have will help the guys help you.
  • boyscout862 and 637Yeoman have said thanks
#3 Bolens 1000 ONLINE
  • 14,617 Thanks
  • 17,959 posts
Posted April 26, 2017 - 04:03 PM
Welcome !
I assume this is a Bolens???
Have any pictures?
#4 James Bosma ONLINE
James Bosma
  • 767 Thanks
  • 390 posts
Posted April 26, 2017 - 04:47 PM
Did someone mention the PIC word again :dancingbanana:
We love pictures :)
As mentioned before  pics of tractor and decks
Picture is worth a thousand words and are sometimes easier to understand what help you need
Have you downloaded the manual for the tractor
Odds are that the manual is here in the manual section
You are allowed 3 downloads a day
#5 Newpaws493 OFFLINE
Newpaws493
  • 1,362 Thanks
  • 1,808 posts
Posted April 26, 2017 - 06:24 PM
We love pictures :)
   :yeah_that:    and :welcometogttalk:
  • James Bosma said thank you
#6 boyscout862 ONLINE
  • 11,847 Thanks
  • 8,688 posts
Posted April 26, 2017 - 07:07 PM
Welcome to GTT. Check out our Manuals Section for info that you need. There are brouchures too. They can help you identify the decks. Good Luck, Rick
#7 Grandpa's G14 OFFLINE
Grandpa's G14
  • 9 Thanks
  • 9 posts
Posted April 27, 2017 - 12:57 AM
I'll check out the manuals. I have the 20lb original manual around somewhere. I wanted to reiderate when I said against my parents wishes I took the tractor. My grandfather loved his tractors, was a mechanic, and told me to take all his gear head stuff before he passed as I was the only mechanic wise person left in the fam. As his knees have out in his 70's and I was 15, I had to do all his dirty work on machines while he yelled from above with cigar in mouth. I had to take the tractors before his house was gobbled up by a new hospital.
Pics tomorrow.
G14 1453 model
171.6786 or 171.8788. But I think the first(paint over gear box numbers)
  • Newpaws493 said thank you
#8 Newpaws493 OFFLINE
Newpaws493
  • 1,362 Thanks
  • 1,808 posts
Posted April 27, 2017 - 06:00 AM
It seems reasonable from here, if not honorable to follow up on his requests and continue that relationship through these tractors and other things. I can also relate to not always being on the same page with family on some issues. I'm kinda hoping they might come around to understanding why you chose your path in this. Likewise if the tractors aren't being kept at their place it should be, IMO, less of an issue for conflicts. Good Luck in continuing the legacy. my $00.02. Gt related, you've definitely come to the right place, enjoy GTtalk. :thumbs:
#9 Grandpa's G14 OFFLINE
Grandpa's G14
  • 9 Thanks
  • 9 posts
Posted April 28, 2017 - 12:08 AM
Here are the decks. Forgot the g 14, but included 6 moth old pics of them. Been busy trying to flip two houses, but would love to cut their lawns with the Bolens as they sit in the market here in NJ.
  • Bolens 1000 and pryan05 have said thanks
#10 Grandpa's G14 OFFLINE
Grandpa's G14
  • 9 Thanks
  • 9 posts
Posted April 28, 2017 - 12:12 AM
You guys already made me realize there is some linkage on the rusty seat "parts" g14 that I may need. That tractor is at my rental property "other late grandpas inherited house".
#11 Bolens 1000 ONLINE
  • 14,617 Thanks
  • 17,959 posts
Posted April 28, 2017 - 07:10 AM
For the green deck use parts list:
http://gardentractor...420-01-42inpdf/
For the Black deck with all the spring bracket mounts use manual:
http://gardentractor.../1413-18423pdf/
#12 Grandpa's G14 OFFLINE
Grandpa's G14
  • 9 Thanks
  • 9 posts
Posted April 28, 2017 - 08:23 AM
Thanks for those diagrams! Do you suggest one over the other, green vs. black? And my black deck doesn't seem to have, or ever had a front roller. There are no weld spots on the deck to indicate it was ever there.
By the way. With correct linkage will both decks fit my g-14?
Thanks
John
#13 Grandpa's G14 OFFLINE
Grandpa's G14
  • 9 Thanks
  • 9 posts
Posted April 28, 2017 - 08:24 AM
Thanks
John
  • Newpaws493 and pryan05 have said thanks
#14 Grandpa's G14 OFFLINE
Grandpa's G14
  • 9 Thanks
  • 9 posts
Posted April 29, 2017 - 05:46 PM
Well that video I posted didn't work. Anyway, any difference between the black or green decks. I'm guessing I should go with the one I'm best repair. I am only missing a few links at this point . Also, seems thenignitionni bought at autozone fried my 20 amp fuse. Going to stick the original back in there but have no key. I think my grandfather used to use a flathead to start it. The auto zone ignition kept the starter cranking even after the mother was running, I had to turn key back to off for it to. Ot burn out. There's the other issue, there was no kill switch/off position so I had to choke it to turn it off.
Any experience with this. I prob should just fork over the $55 for a new original ignition, but would like an alternative.
Thanks
John
  • pryan05 said thank you
#15 Grandpa's G14 OFFLINE
Grandpa's G14
  • 9 Thanks
  • 9 posts
Posted April 30, 2017 - 08:25 PM
My opening to this thread I said I was "trolling here for a year". I thought trolling meant reading posts but not joining the group lol.
Anyway another question. Is My g14 is hydrostatic? I assume it is.
Finally got one cover off my black mower deck, every pulls has to be replaced as they are broken or rusty. Have to sawsall the green mower deck cover off and see what's up inside tomorrow. Figure I should replace EVERYTHING in one of my decks while I'm in this process to get a fault free reliable cutter.
Thanks
