Kohler CV15s hydraulic lifter problems"your input needed"
2 replies to this topic
#1 aftonarrow OFFLINE
aftonarrow
  • 1 Thanks
  • 8 posts
Posted April 26, 2017 - 02:06 PM
Hi,I have a kohler cv15s hydro lifters with non adjustable rocker arms.There is no clearance on the exhaust valve and the pushrod is actually keeping the intake valve from sealing.The starter will stop and the motor will backfire out the intake because of the valve staying open.I have the lifters out and going to disassemble,clean and reassemble.To me this is a terrible design of a motor.Im guessing the oil pressure makes it work?How do I set them after a put them back together?I changed my oil from 30w to the Kohler 10w30 oil with Kohler filter.Im already in it with a headgasket.I don't want to bend push rods so if anyone can help me or had a problem like this.Please comment,thanks.
#2 GardnMastr OFFLINE
GardnMastr
  • 403 Thanks
  • 205 posts
Posted April 26, 2017 - 02:20 PM
Hundreds of thousands of car engines and thousands of lawn engines are built this way. I would stick the lifter in a press. Push down on them, on the inside, with a wooden dowel, and bleed some of the oil out of them. When you assemble, the adjustment is backed off. Engine oil pressure will pump them up to where they need to be.
#3 MiCarl OFFLINE
MiCarl
  • 2,210 Thanks
  • 1,127 posts
Posted April 26, 2017 - 06:41 PM
I know on motorcycles tappets are generally pre-filled with kerosene before assembly.  I presume it's because kerosene will bleed off easily enough they don't hold valves open on start up.
