L111 B&S VTwin Carb Throttle/Choke Linkages
linkage l111 vtwin carb choke rods
3 replies to this topic
#1 tjsolimeo OFFLINE
tjsolimeo
  • 1 Thanks
  • 3 posts
Posted April 26, 2017 - 11:36 AM
Had to replace a broken choke shaft. Easy job, but I didn't get any pics of the choke and throttle link orientations. The link rods are different shapes and lengths and it would be great if someone had, or could take, a few pics of the rods installed.
It was painful enough to pay $25 for a small plastic shaft so I would like to not have to buy an expensive manual.
Thanks for the help,
Tom S.
#2 Bolens 1000 OFFLINE
  • 14,978 Thanks
  • 18,136 posts
Posted April 26, 2017 - 11:51 AM
Dont have any engines here to take a pic of but I do stock the service manual
http://bolenspartsan...reprint-273521/
  • tjsolimeo said thank you
#3 tjsolimeo OFFLINE
tjsolimeo
  • 1 Thanks
  • 3 posts
Posted April 27, 2017 - 12:38 PM
I appreciate your help and will order the manual. I just spent the time and reassembled everything correctly. Taking the hood off made it all a lot easier. The engine still won't stay running, but it seems to be the fuel cutoff solenoid. It won't pass air when energized, so I guess fuel won't flow either.It would be nice if I can remove it without disassembling the carb and just replace it with a plug for now.
Thanks again,
Tom S.
  • Bolens 1000 said thank you
#4 Bolens 1000 OFFLINE
  • 14,978 Thanks
  • 18,136 posts
Posted April 27, 2017 - 03:21 PM
Thanks for the order!
You should hear the solenoid "Click" off when you turn the key to the on position. It seems like they are either good or bad
Also tagged with one or more of these keywords: linkage, l111, vtwin, carb, choke, rods
