running lean on a 1256
21 replies to this topic
#16 Bolens 1000 OFFLINE
  • 17554 Thanks
  • 18863 posts
Posted May 03, 2017 - 06:35 PM
#17 hiltu OFFLINE
hiltu
  • 17 Thanks
  • 37 posts
Posted May 05, 2017 - 05:06 PM
So im pretty sure thats the numbers i got earlier, i rotated the crank until the valves dropped and used a feeler gauge to obtain them.
#18 Bolens 1000 OFFLINE
  • 17554 Thanks
  • 18863 posts
Posted May 05, 2017 - 05:38 PM
I'm wondering if you dont have a faulty ignition system
Carb is good, valves are good , motor has new piston rings ect.
#19 hiltu OFFLINE
hiltu
  • 17 Thanks
  • 37 posts
Posted May 05, 2017 - 08:29 PM
All ignition is new except the part on the front of the crank. I kept all old stuff, so i could go about changing things out.
#20 hiltu OFFLINE
hiltu
  • 17 Thanks
  • 37 posts
Posted May 09, 2017 - 03:26 AM
Anything I should try to replace first? I am still pondering the carb. Up until i removed the needle valve from the main jet, nothing i did could get the motor to run rich. After reinserting it, I got unburnt fuel smoke and a dark spark plug. I was thinking the coil first?
#21 Bolens 1000 OFFLINE
  • 17554 Thanks
  • 18863 posts
Posted May 09, 2017 - 07:52 AM
I think you can rule out the carb it did respond when I made adjustments on the main jet, its loose and turns from vibration at times but other than that I have found nothing wrong with it when I tested it for an hour.
I still think valves or ignition may be your issue , did the shop vap or reface the valves to make sure they are seating correctly?
Are you using fresh gas?
#22 framesteer OFFLINE
framesteer
  • 530 Thanks
  • 254 posts
Posted May 09, 2017 - 07:47 PM
Could be that the gas tank cap is not venting properly.  If it isn't venting properly, the engine may run fine for a while (after removing and replacing the gas cap), then the tank will pull a slight vacuum and the fuel will stop flowing to the carb.  The engine will run lean and eventually die.
  • Bolens 1000 said thank you
