My neighbor has an Allis c and the oil line that goes into the governor area keeps coming out is there something that is supposed to hold that in ?
Allis chalmers c governor oil line problem
Started by
bolens1053
, Jun 13, 2011 10:02 PM
5 replies to this topic
#1
OFFLINE
Posted June 13, 2011 - 10:02 PM
#2
OFFLINE
Posted June 19, 2011 - 03:25 PM
I don't know if you got this figured out yet or not but I figured I would at least get your thread bumped so maybe someone will see it that can help.
Is there an internal o-ring? Is the tip of the oil line bulged out at all? If it is there is more then likely an internal o-ring and when the o-ring is in good shape it basically clamps it tight enough to seal and hold it in.
#3
OFFLINE
Posted June 19, 2011 - 04:58 PM
I would think it should have either a brass ferrule or a flat rubber grommet that gets tightened snug by the fitting. Not being familiar with the tractor, that's as much as I can offer.
#4
OFFLINE
Posted June 19, 2011 - 05:24 PM
I have not run a C since I was in high school. M father-in-law had a WD45 and as i recall it was a standard brass fitting(flare nut) on the oil line.
#5
OFFLINE
Posted June 19, 2011 - 05:30 PM
If that's the case, then the flare has simply broken off the line. A flare tool & a minute of time, and it'll be fixed.
#6
OFFLINE
Posted June 24, 2011 - 07:20 AM
Thanks for all your help guys I'll have to take another look at it
