Added a 16hp variable speed to the herd!
13 replies to this topic
#1 adamjd200 OFFLINE
adamjd200
  • 2,086 Thanks
  • 2,202 posts
Posted April 25, 2017 - 03:07 PM
Bought this on Saturday for $200, starts and runs good, needs a little TLC, previous owner said the variable speed eats belts when used in low, have to look into it, a buddy of mine who does machine work told me the pulley has ridges worn into it ( said he's seen that before) usually turning the pulley down .0020 one the inside on a lathe fixes that, otherwise I need to reinstall the brake drum (not sure why it was removed), and install a new starter generator belt, and should be good to go.
IMG_20170425_154157.jpg IMG_20170425_154207.jpg IMG_20170425_154216.jpg IMG_20170425_154357.jpg IMG_20170425_154223.jpg IMG_20170425_154412.jpg
  • Gtractor, KennyP, CRFarnsworth and 7 others have said thanks
#2 Merle013 ONLINE
Merle013
    If I can't do it slow then it's not going to get done.
  • 267 Thanks
  • 183 posts
Posted April 25, 2017 - 03:14 PM
Nice find. Congrats.
  • boyscout862 and adamjd200 have said thanks
#3 KennyP ONLINE
  • 40,192 Thanks
  • 46,794 posts
Posted April 25, 2017 - 06:12 PM
Nice MW! Hope your buddy get that pulley fixed up for you.
  • adamjd200 said thank you
#4 637Yeoman OFFLINE
637Yeoman
  • 1,551 Thanks
  • 1,254 posts
Posted April 25, 2017 - 08:21 PM
You bought that cheap!
#5 adamjd200 OFFLINE
adamjd200
  • 2,086 Thanks
  • 2,202 posts
Posted April 25, 2017 - 09:05 PM
I know, didn't think I'd get it, the way stuff was selling at that sale.
  • KennyP and 637Yeoman have said thanks
#6 TomLGT195 OFFLINE
TomLGT195
  • 4,016 Thanks
  • 2,884 posts
Posted April 26, 2017 - 06:24 AM
What's the cover down in front protecting? Looks awful low to the ground.
 Otherwise, Nice find at a good price!
Edited by TomLGT195, April 26, 2017 - 06:25 AM.
#7 adamjd200 OFFLINE
adamjd200
  • 2,086 Thanks
  • 2,202 posts
Posted April 26, 2017 - 08:29 AM
That covers the belt drive from the PTO to the drive shaft for the tiller.
#8 adamjd200 OFFLINE
adamjd200
  • 2,086 Thanks
  • 2,202 posts
Posted April 27, 2017 - 09:29 PM
After looking at the variator a little closer, the pulley on the transaxle is very loose, pretty sure that is why it's eating belts.
  • 637Yeoman said thank you
#9 Sprint 6 ONLINE
Sprint 6
  • 253 Thanks
  • 308 posts
Posted April 29, 2017 - 05:36 AM
The torsion spring in the hub may be broken.  The spring is there to dampen vibrations in the drive line.
Edited by Sprint 6, April 29, 2017 - 05:37 AM.
#10 adamjd200 OFFLINE
adamjd200
  • 2,086 Thanks
  • 2,202 posts
Posted April 29, 2017 - 06:59 AM
I will have to pull it off and see what is going on, I'm guessing that this spring is hard to get?
#11 Sprint 6 ONLINE
Sprint 6
  • 253 Thanks
  • 308 posts
Posted April 29, 2017 - 07:59 AM
Probably a Gilson part that may be unobtainium. I have had the hub get loose on mine.
#12 lrhredjb ONLINE
lrhredjb
  • 799 Thanks
  • 616 posts
Posted April 29, 2017 - 09:59 AM
So that variable speed setup is like a CVT ?
#13 adamjd200 OFFLINE
adamjd200
  • 2,086 Thanks
  • 2,202 posts
Posted April 29, 2017 - 12:27 PM
Worst case I will just solid mount that pulley like any other brand would have.
#14 Sprint 6 ONLINE
Sprint 6
  • 253 Thanks
  • 308 posts
Posted April 29, 2017 - 01:28 PM
Essentially, yes. Except only the drive pulley changes diameter, by changing its width.
