Pulling hitches
7 replies to this topic
#1 Macmagee OFFLINE
Macmagee
  • 30 Thanks
  • 67 posts
Posted April 24, 2017 - 08:30 PM
Can you guys post some pics of your hitches so I can get some kind of ideas thanks.
  • 637Yeoman said thank you
#2 637Yeoman ONLINE
637Yeoman
  • 1,570 Thanks
  • 1,272 posts
Posted April 24, 2017 - 08:58 PM
Dont have a pic right now, but i just use a 3 inch diameter circle, about 1/2" thick.
Do NOT put the hitch above the axle, you will flip over as soon as you let the clutch out, if you have traction
Edited by 637Yeoman, April 24, 2017 - 09:39 PM.
#3 637Yeoman ONLINE
637Yeoman
  • 1,570 Thanks
  • 1,272 posts
Posted April 24, 2017 - 09:23 PM
#4 DaveBb OFFLINE
DaveBb
  • 405 Thanks
  • 173 posts
Posted April 30, 2017 - 10:37 AM
Here is a simple hitch to make and its adjustable...
#5 637Yeoman ONLINE
637Yeoman
  • 1,570 Thanks
  • 1,272 posts
Posted May 02, 2017 - 12:14 PM
I need to make something like that. Is that a cub rear end? How much does it take to build a motor?
The frame etc. isnt a concern, my dad builds stuff like that everyday.
#6 DaveBb OFFLINE
DaveBb
  • 405 Thanks
  • 173 posts
Posted May 02, 2017 - 06:47 PM
yes its a cub diff housing but everything inside has been replaced. Dodge Dart Carrier and axles and aftermarket gears and shafts. You can look at my build in Building another puller..
Edited by DaveBb, May 02, 2017 - 06:48 PM.
#7 Macmagee OFFLINE
Macmagee
  • 30 Thanks
  • 67 posts
Posted May 30, 2017 - 03:05 PM
I just read my rules about hitches it says altered hitches may not exceed 12 inches .waiting for an answer on what is a altered hitch and height of wheelie off the ground.i am building a hitch and want to build it to the rules so I don't want to show up and not being to pull because of the wrong size or placement of hitch or height of wheelie wheels.
#8 637Yeoman ONLINE
637Yeoman
  • 1,570 Thanks
  • 1,272 posts
Posted May 30, 2017 - 09:32 PM
cant remember if its 12 above axle or ground, i think ground. Altered hitch is one you made, or modified.
  • Macmagee said thank you
