What to repower with
4 replies to this topic
#1 Hellbent OFFLINE
Hellbent
  • 14 Thanks
  • 7 posts
Posted April 24, 2017 - 06:28 PM
Hi y'all new here but not to tractors or mowers. I recently got a simplicity 4211 for free from a friend and am in the midst of restoring it (yeah I know not a desirable Lt but it just to pass time and have fun). Anyway the motor that's on it needs a lot of work but the times it did run for a few seconds it had a knock in the bottom end. So my choices are find a running flat head to repower with (whick here in the south go for $200-$300) or re power with a Briggs intec 10.5 for $310. I'm in the middle I like the idea of a new motor but like the idea of keeping it with a say period correct motor. If y'all were in my shoes which would you choose.
  • chieffan said thank you
#2 TomLGT195 OFFLINE
TomLGT195
  • 3,700 Thanks
  • 2,763 posts
Posted April 25, 2017 - 06:23 AM
I'd re power with whatever i could get cheap that fits without major rework. Find a donor tractor with a good engine that has other issues, could be cheaper than an engine alone.
  • tractorgarden and chieffan have said thanks
#3 karel ONLINE
karel
  • 1,992 Thanks
  • 1,334 posts
Posted April 25, 2017 - 06:28 AM
Go stock!
#4 chieffan ONLINE
  • 9,623 Thanks
  • 6,434 posts
Posted April 25, 2017 - 07:27 AM
Never was a fan of the B&S Intek.  They don't last and any used one you get is probably on its last leg.  Not sure on the new ones ans I think they redesigned them for the Simplicity line.  Should be able to pick up a parts tractor with a good motor for a lot less than $2-300.
#5 Trav1s ONLINE
Trav1s
  • 3,200 Thanks
  • 4,299 posts
Posted May 01, 2017 - 03:45 PM
Originally a Briggs 11 vertical shaft, right?
Small Engine Warehouse does not have anything but shows it as a 1" shaft
http://www.smallengi...-4211-Category/
This might work:
http://www.smallengi...390UT1DETR.html
Or find something and give it a DIY whirl.
Edited by Trav1s, May 01, 2017 - 03:47 PM.
