Tractor will not start
1 reply to this topic
#1 Macmagee OFFLINE
Macmagee
  • 30 Thanks
  • 67 posts
Posted April 24, 2017 - 02:30 PM
I started the tractor with the ignition switch moved it to the driveway changed the oil went to start it nothing pushed in on the safety under the seat and still nothing jumped the selonoid and it started. Without pushing in on the safety switch and jumping the selonoid it just spins over no start. What do you guys think ignition switch ? I might try unplugging the safety switch and put a jumper and see what happens let me know thanks.
#2 boyscout862 OFFLINE
  • 13,692 Thanks
  • 9,475 posts
Posted April 24, 2017 - 03:56 PM
Clean the wire connections and grounds first. Make sure the oil level is full(low oil safety sensor). Good Luck, Rick
  • 637Yeoman said thank you
