another kohler k series fuel pump question
9 replies to this topic
#1 dodge trucker OFFLINE
dodge trucker
  • 2,296 Thanks
  • 3,013 posts
Posted April 22, 2017 - 09:30 PM
just got the K341 on an Ariens S16h running for the 1st time in who knows how long earlier today... tried something that usually works for me as a temporary fuel supply to make sure I had "good" gas getting to it, but today it didn't work.
This one has a primer lever on the pump.  It didn't prime up, so I grabbed a spare "loose" tank and set it on top of the engine, Soon as I opened up the shutoff, the gas flowed thru the pump like it was just a piece of hose.... I think I know, but that isn't supposed to do that, right?
I searched here and found the Kohler fuel pump kits in a couple of other threads, but there are 4 different kits available... any way to tell which kit I need without pulling it apart to match up the plunger on the diaphragm? I don't want one of the POS  pumps that they sell for these engines these  days....
  • chieffan said thank you
#2 chieffan ONLINE
  • 9,523 Thanks
  • 6,393 posts
Posted April 22, 2017 - 10:23 PM
I usually put an electric pump in the line and don't worry about the non working mechanical pump.  Usually cheaper and easier than messing with the original pump.
#3 boyscout862 OFFLINE
  • 12,517 Thanks
  • 9,028 posts
Posted April 22, 2017 - 10:43 PM
Where did the gas flow to? Besure it didn't go into the oil sump. I picked up a NOS Kholer pump rebuild kit at a swap meet last week. They are still atound. Good Luck, Rick
#4 dodge trucker OFFLINE
dodge trucker
  • 2,296 Thanks
  • 3,013 posts
Posted April 22, 2017 - 10:46 PM
I unhooked the fuel pump outlet hose  where it goes into the carb inlet and as soon as I opened the valve on the temporary tank held above the engine, came out that fuel line.... re hooked it to the carb and the engine took off and ran, I don't really want to put an electric on this machine though I have done so with others in the past.
#5 dodge trucker OFFLINE
dodge trucker
  • 2,296 Thanks
  • 3,013 posts
Posted April 22, 2017 - 10:48 PM
and boyscout... the website that is linked to in a few places here, shows 4 different kits to fit seemingly "the same" Kohler pumps.... from back in the day were there multiple kits available from Kohler for them as well?
#6 GardnMastr OFFLINE
GardnMastr
  • 344 Thanks
  • 178 posts
Posted April 23, 2017 - 07:58 AM
I think the plastic pumps are the best from my experience, the plastic does not transfer as much heat from the body of the pump to the fuel.
#7 LilysDad ONLINE
LilysDad
    Millennium Falcon
  • 12,964 Thanks
  • 9,611 posts
Posted April 23, 2017 - 08:26 AM
It's not that hard to pull the pump apart and check the shape of the diaphram.
#8 dodge trucker OFFLINE
dodge trucker
  • 2,296 Thanks
  • 3,013 posts
Posted April 23, 2017 - 01:27 PM
never said it was.....
#9 LilysDad ONLINE
LilysDad
    Millennium Falcon
  • 12,964 Thanks
  • 9,611 posts
Posted April 23, 2017 - 02:40 PM
sorry
#10 secondtry OFFLINE
secondtry
  • 1,676 Thanks
  • 1,278 posts
Posted April 23, 2017 - 06:52 PM
 I have a bad pump my self. Will be interested in any real answers you get. Don
