Unidenfied Metal Object
21 replies to this topic
#1 HANKG ONLINE
HANKG
  • 6,311 Thanks
  • 3,423 posts
Posted April 21, 2017 - 06:42 AM
After popping of the flywheel of my K91, I found this lying on the floor, after a thorough inspection of the parts list and finding no match I'm left with '' WHATZAT IMG_1808.JPG ''
  • MH81 and hamman have said thanks
#2 MH81 OFFLINE
Posted April 21, 2017 - 06:44 AM
Almost looks like a ground lug wire connection.
Over all length and thickness?
Edited by MH81, April 21, 2017 - 06:44 AM.
  • HANKG said thank you
#3 glgrumpy OFFLINE
  • 8,609 Thanks
  • 7,920 posts
Posted April 21, 2017 - 07:25 AM
I would say wire with slip on end goes on to this, hooked on with a screw. If Briggs, the upper screw on  the points covers sometimes had these on bigger engines for mag ground shut-off.
#4 Bolens 1000 OFFLINE
  • 14,987 Thanks
  • 18,140 posts
Posted April 21, 2017 - 07:42 AM
I have no Idea, just took apart my K90 and found nothing like that
  • EricFromPa and HANKG have said thanks
#5 637Yeoman OFFLINE
637Yeoman
  • 1,551 Thanks
  • 1,254 posts
Posted April 21, 2017 - 07:47 AM
Thats a thingy ma-bob
  • HANKG and karel have said thanks
#6 HANKG ONLINE
HANKG
  • 6,311 Thanks
  • 3,423 posts
Posted April 21, 2017 - 08:15 AM
OVL 1 1/4  1/16th stiff brass maybe
#7 classic OFFLINE
classic
  • 5,209 Thanks
  • 2,248 posts
Posted April 21, 2017 - 08:19 AM
Looks like one of those keepers that hold the end of a recoil start spring in place. Whatever it's for, the person who lost it probably looked for it for hours. I blamed a chicken for eating a needle roller bearing for a T92 transmission. There's supposed to be 13 and I only had 12. One of my chickens was hanging out by the parts when I had them laid out and I said, "crap, she ate one!" I was gonna follow her around to get it back, but I said the heck with it. I found the thirteenth bearing on the work bench two days later, HA!
  • EricFromPa, Billy M, HANKG and 1 other said thanks
#8 HANKG ONLINE
HANKG
  • 6,311 Thanks
  • 3,423 posts
Posted April 21, 2017 - 08:20 AM
I like your answer, it makes sense but I have yet to find the spot.
#9 HANKG ONLINE
HANKG
  • 6,311 Thanks
  • 3,423 posts
Posted April 21, 2017 - 08:23 AM
I will investigate that plausible possibility ( NOT THE CHICKEN PART THOUGH )
  • Billy M, classic and 637Yeoman have said thanks
#10 HANKG ONLINE
HANKG
  • 6,311 Thanks
  • 3,423 posts
Posted April 21, 2017 - 08:32 AM
Going to check the schnacke recoil parts list. NOPE.
Edited by HANKG, April 21, 2017 - 08:37 AM.
#11 637Yeoman OFFLINE
637Yeoman
  • 1,551 Thanks
  • 1,254 posts
Posted April 21, 2017 - 08:35 AM
Are you sure it wasnt there before you took the recoil off?
#12 boyscout862 ONLINE
  • 12,851 Thanks
  • 9,171 posts
Posted April 21, 2017 - 09:03 AM
I've seen a part like that before but I'm not sure what engine it was on. It was a keeper for holding the flywheel key inplace or the flywheel nut. Good Luck, Rick
#13 Cat385B ONLINE
    HAZMAT CAT
  • 13,974 Thanks
  • 10,002 posts
Posted April 21, 2017 - 09:09 AM
Did you ever sneeze during this work? If so, consult a physician.
  • MH81 and HANKG have said thanks
#14 classic OFFLINE
classic
  • 5,209 Thanks
  • 2,248 posts
Posted April 21, 2017 - 09:48 AM
Boyscout, the Briggs 23D has a keeper for the flywheel similar to that thing, but it has two holes in it.
  • boyscout862 and HANKG have said thanks
#15 EricFromPa OFFLINE
EricFromPa
  • 3,658 Thanks
  • 3,113 posts
Posted April 21, 2017 - 11:39 AM
Was thinking wire lug that's missing the locking collar. Had a couple old garden tractors here that had battery terminals like that. There brass or copper with a locking collar that you slide the wire in and tighten down with a screw or small bolt.
like this one
  • MH81, Cvans and HANKG have said thanks
