how to wire sprayer
21 replies to this topic
#1 gary990 OFFLINE
gary990
  • 15 Thanks
  • 42 posts
Posted April 20, 2017 - 10:33 AM
hi guys i got a pull Srayer off of craigs list. it is a top air, the pump that is a flow-jet has a black and a red wires coming off it i went to install a on off switch about half way up then wired off the switch to the battery, when i turn it on it works but the wires get hot to the point of melting, i have tried 3 different switches does the same. if i hook it up without the switch it works fine, but i need to turn it off, what can i put in for an off and on that will work.
#2 GardnMastr OFFLINE
GardnMastr
  • 344 Thanks
  • 181 posts
Posted April 20, 2017 - 10:42 AM
Your wires to the switch are too small. Gauge, diameter, I don't know your terminology or understanding. You need a bigger electrical "pipe".
#3 gary990 OFFLINE
gary990
  • 15 Thanks
  • 42 posts
Posted April 20, 2017 - 10:50 AM
the wires coming off the pump are the same size and from the switch are bigger yet. it only gets hot from the switch to the batt.
#4 KennyP ONLINE
  • 37,401 Thanks
  • 45,453 posts
Posted April 20, 2017 - 11:00 AM
What is the amperage rating of the switch? And how many amps does the pump pull?
#5 GardnMastr OFFLINE
GardnMastr
  • 344 Thanks
  • 181 posts
Posted April 20, 2017 - 11:02 AM
Resistance causes heat. The hot spot is where the resistance is.
  • MH81 and boyscout862 have said thanks
#6 gary990 OFFLINE
gary990
  • 15 Thanks
  • 42 posts
Posted April 20, 2017 - 11:07 AM
the switch is 20 amps, i can not read the pump it is wore off. i even tired a electric motor switch,
#7 GardnMastr OFFLINE
GardnMastr
  • 344 Thanks
  • 181 posts
Posted April 20, 2017 - 11:15 AM
So then, the pump is not new. It could be pulling too many amps because it has motor trouble. Do you have a fuse on it? Has it blown? Does it seem to operate well wired direct? I would install a relay. A small current operates the big switch, which can handle a larger load.here is a picture of 3 relays that could be used.image.jpg
#8 larrybl ONLINE
larrybl
    Texas Member
  • Site Supporter
  • 6,856 Thanks
  • 4,348 posts
Posted April 20, 2017 - 11:20 AM
You could use an AMP meter (I suggest a regular Automotive one) as a multimeter is usually rated at 10 amps. to see what the draw is.
#9 gary990 OFFLINE
gary990
  • 15 Thanks
  • 42 posts
Posted April 20, 2017 - 11:32 AM
when i hoke it up straight works fine.ill try a new relay is that hooked up before the switch.
#10 chieffan ONLINE
  • 9,540 Thanks
  • 6,399 posts
Posted April 20, 2017 - 12:57 PM
Sounds like it could be a bad connection at the switch from the battery.  I have a trailer sprayer and put a standard 15A lamp cord in line switch in and works fine for several years.
#11 Billy M OFFLINE
Billy M
  • 624 Thanks
  • 536 posts
Posted April 20, 2017 - 03:40 PM
Don't forget to consider the length of run when sizing wires.  Once you know the amps you are pulling, there are plenty of charts on the interwebs that give recommended wire size in relation to amps and length of run.  Here's an example...
american-wire-gauge-awg-.jpg?t=145528184
  • JBRamsey and GardnMastr have said thanks
#12 chieffan ONLINE
  • 9,540 Thanks
  • 6,399 posts
Posted April 20, 2017 - 03:46 PM
If you use a relay, be sure you get it wired in correctly in place of the switch.  Will probably have 4 wire terminals or connecting points.  Without know or see which relay you decide to use, hard to tell with wire goes where.  You will still use your switch to activate the relay but honestly, I don't think you need it.  If the wire between the battery and the switch is the only one getting hot, like GardnMastr  said, resistance is causing the heat.  Bad wire connections at the switch, or a bad switch.
#13 GardnMastr OFFLINE
GardnMastr
  • 344 Thanks
  • 181 posts
Posted April 20, 2017 - 04:34 PM
This may help somebody, sometimes I forget that people have different knowledge or background.image.jpg
  • chieffan said thank you
#14 KennyP ONLINE
  • 37,401 Thanks
  • 45,453 posts
Posted April 20, 2017 - 06:12 PM
This may help somebody, sometimes I forget that people have different knowledge or background.attachicon.gifimage.jpg
There some of us that you pic still is Greek!
  • chieffan and GardnMastr have said thanks
#15 chieffan ONLINE
  • 9,540 Thanks
  • 6,399 posts
Posted April 20, 2017 - 06:22 PM
That looks like a Radio Shack relay to me.  Have used a bunch of them.  Nice thing is they usually have the wiring diagram on the package and most are rated at 30A.
  • GardnMastr said thank you
