Press Brake for 20 ton shop press
8 replies to this topic
#1 bbuckler ONLINE
bbuckler
  • 2,855 Thanks
  • 2,535 posts
Posted April 17, 2017 - 06:39 PM
I'm hoping to pick up a 20 ton press this weekend and I found this.
http://www.swagoffro...r-Kit_p_40.html
Be good to make battery boxes for gts.
  • Alc, hamman, KennyP and 4 others have said thanks
#2 KennyP ONLINE
  • 34,253 Thanks
  • 43,378 posts
Posted April 17, 2017 - 06:56 PM
Looks simple to build! Gives me ideas!
  • boyscout862 and bbuckler have said thanks
#3 bbuckler ONLINE
bbuckler
  • 2,855 Thanks
  • 2,535 posts
Posted April 17, 2017 - 06:57 PM
I was thinking the same thing can build it a lot cheaper too
#4 JBRamsey OFFLINE
JBRamsey
  • 1,267 Thanks
  • 738 posts
Posted April 17, 2017 - 07:00 PM
For bending boxes, get the finger brake.
#5 bbuckler ONLINE
bbuckler
  • 2,855 Thanks
  • 2,535 posts
Posted April 17, 2017 - 07:16 PM
I just looked at them and you right a lot better for the boxes. In the video he was bending some thicker metal than I thought it would bend.
#6 EricFromPa OFFLINE
EricFromPa
  • 3,111 Thanks
  • 2,815 posts
Posted April 17, 2017 - 07:59 PM
Ya me to. I could fabricate a new deck shell with that and my uncles plasma cutter instead of patching mine again.
Wonder what gauge steel it can bend? I can get 11ga 4x10 sheets of ASTM A606 COR-TEN for $190.
Cor-Ten is high strength and corrosion resistant. 1 Sheet will make a 50" fab deck with some well planned cutting and a plasma cutter. Lots of extra cutting and welding would be needed with a press brake that small.
I have 4 sets of spindles with replaceable bearings and a couple rough Cub Cadet decks for the mounting hardware.
Edited by EricFromPa, April 17, 2017 - 08:09 PM.
#7 Achto ONLINE
Achto
  • 171 Thanks
  • 74 posts
Posted April 17, 2017 - 08:47 PM
I'm building one now with a 1" round die to make a bend for a hood that I am making.
#8 boyscout862 ONLINE
  • 11,478 Thanks
  • 8,480 posts
Posted April 17, 2017 - 10:32 PM
HF used to sell a press brake for use with their shop presses. I have a couple of home made hand brakes that are handy for small light work but I was thinking of making a press brake for my 30 ton press to handle small heavier work.
A friend built the Mother Earth News brake years ago and I used his for awhile. It is an excellant design and easy to use. I will try to find the plans.
Years ago, I collected some 4" x 4" x 1/2" x 9' angles to make an 8' brake for pickup bodies. I also collected some 3/4" x 12' snow plow cutting edges.  If you can pick up a used cutting edge from your town garage or scrap yard, the holes in the steel will make it easier to assemble. Good Luck Rick
These are the plans for a brake  http://diybooksplans...l Box Brake.pdf
Use several different lengths of channels to get it to work like a finger brake.
Edited by boyscout862, April 17, 2017 - 11:52 PM.
#9 karel OFFLINE
karel
  • 1,827 Thanks
  • 1,214 posts
Posted April 18, 2017 - 01:09 AM
Well if that don't beat all. I bought a harbor freight 606o3 yesterday to press generator bearings. nice idea that press break!
Edited by karel, April 18, 2017 - 01:11 AM.
