JD 200 series deck setup
3 replies to this topic
#1 glenford7502 OFFLINE
glenford7502
  • 102 Thanks
  • 72 posts
Posted April 14, 2017 - 10:06 PM
Just curious if anyone had an operators manual for a mower deck on a 200 series. I'm interested in how exactly you set all the adjustodeck mounts up. And help would be awesome thank you
#2 KennyP ONLINE
  • 38,243 Thanks
  • 45,876 posts
Posted April 15, 2017 - 06:37 AM
Look for a PM.
  • glenford7502 said thank you
#3 ehresmann OFFLINE
ehresmann
  • 1 posts
Posted August 10, 2017 - 09:46 AM
I just recently bought a JD 212 and unsure how to set the height and get the deck level.  Can you share details with me as well?
#4 Cat385B ONLINE
    HAZMAT CAT
  • 13,967 Thanks
  • 9,999 posts
Posted August 10, 2017 - 03:56 PM
The height of cut is set by the adjustment knob between your feet. Lift the deck up with the big lever left of the dash tower, set height by rotating knob to desired height, lower deck by lowering lift lever.
Deck level is attained by using the threaded rods on the draft arms from the front of the deck to the front frame of the tractor. You want the deck pitched forward, so the blades are 1/8 lower at the front than at the back of the deck. Side to side level is by the one back deck hanger that is threaded.
  • Kster526 said thank you
